Old 03-16-2015, 09:30 PM   #1
christopher teed
Default wheel bearing grease
Guys ,just wondering what everybody is using for synthetic wheel bearing grease.. I race in a pure stock drag class and use a tapered bearing..what brands to you guys recommend....and does it make a difference?thanks for any help or comments.Chris
christopher teed is offline   Reply With Quote
Old 03-17-2015, 10:09 AM   #2
Run to Rund
Liked 54 Times in 27 Posts
Default Re: wheel bearing grease
Some guys on yellowbullet recommended Lamb:
http://www.lambcomponents.com/misc-p...g-grease-p-199
Old 03-17-2015, 10:19 AM   #3
tj310
I was given a couple of tubes of synthetic grease that was designed for aircraft wheel bearings operating in the Artic . It was thin !! Ran out and never bothered to look to buy anymore. I now use snowmobile grease. I doubt there is very much to be gained here. ---Trevor
Old 03-17-2015, 01:04 PM   #4
John Dinkel
Liked 264 Times in 69 Posts
Thumbs up Re: wheel bearing grease
I use Mobil 1. Don't know if there is anything better. There probably isn't much advantage no matter what you use.
John Dinkel 3295 STK
John Dinkel is offline   Reply With Quote
Old 03-17-2015, 02:08 PM   #5
tim worner
Liked 126 Times in 20 Posts
Valvoline SYN Power grease part#W985
Tim Worner SS 1747
tim worner is offline   Reply With Quote
Old 03-17-2015, 05:37 PM   #6
Mike Washington
Liked 6 Times in 2 Posts
When I used to use grease it was Lamb. Haven't used grease since we switched over to Jack's Bearings.
Mike Washington is offline   Reply With Quote
Old 03-17-2015, 06:34 PM   #7
FED 387
Liked 334 Times in 181 Posts
Most any of the Lithium 220 series greases will work well--Timken/Mobil 1 ETC.
