Liked 520 Times in 132 Posts
What is the minimum thickness a rear engine plate should be?
Liked 204 Times in 54 Posts
I use 0.090 steel and wouldn't go thinner....
Liked 99 Times in 60 Posts
Duce,
The two common mid plates are 1/4" aluminum and .090 steel. "Generally" you see the 1/4" plate in dragsters and tube frame cars. "Generally" you see the .090" steel plate in back half door cars. I do not recall seeing any other options. With my super 10 build I have 1/4" aluminum front, 090" steel middle.
Larry Woodfin 471W |
Liked 125 Times in 59 Posts
I do have 3/16" aluminum mid in my car with 1/4" front. Been running it for years. They are pretty narrow in my roadster though.
Curtis |
Liked 332 Times in 180 Posts
Just remember to tell your convertor guy how thick your mid plate is so that you have the correct mounting tabs for proper engagement!!!
Liked 284 Times in 87 Posts
Ed… .090 steel or .250 (T-6 6061) aluminum. MB.
Liked 1,582 Times in 582 Posts
I am using an Aluminum mid plate on my Comp Super Modified car.
Don't see any issue on using an Aluminum Mid Plate on a back-half car if you don't go too thin in the material. |
Liked 6 Times in 4 Posts
Don't forget to use a (for, aft) engine limiter.....
Yes that's what I thought. I'm getting movement. Mine is .250 aluminum in front and .090 steel midplate.
