Old 03-08-2015, 10:20 PM   #1
STR001
Default Front end rise
I have a 87 Camaro stocker that I recently finished. I tested it at the track yesterday. When launching the front end will lift the front wheels about 2 foot off the ground. The front end will recoil and then almost fully extend a second time. The frontend will stay raised up during the entire run. It has Lakewood 90/10 front struts. 50/50 rear. Moroso trick springs 220 lb. rate with 1/2 coil cut. Travel is about 4". Is this a strut or spring issue? Or a combination of both? Any help or suggestions greatly appreciated. Jason
STR001 is offline   Reply With Quote
