Liked 99 Times in 49 Posts
Anyone out there have a header builder that sells flanges?Small block 23* hooker spead bolt pattern
Liked 162 Times in 45 Posts
I recently needed an oddball set. I called Neil and Parks. Great service, parts are right, and timely delivery.
Liked 1,582 Times in 582 Posts
SPD exhaust has the largest selection of exhaust flanges for every car and cylinder head make.
http://www.spdexhaust.com/Header-FlangesB.html |
Jim, I got Jere Stahl to cut a custom set of flanges for a set of Hedman Hustlers that used his bolt pattern. He had me take a file folder, open it up and lay it on the head, and use a gasket hammer to cut it out like making a gasket. Just folded the folder back up, and mailed it to them. With my Heads Up! raised exhaust ports, Hedman's factory flanges didn't put the tube over the port correctly. He had me do the same with my new head, for the new headers they built for me. I feel fortunate to have gotten a set from them shortly before they shut down.
You can probably get SPD, or one of those other header flange makers to do the same for you.
Ed Wright 4156 SS/JA |
Thanks I tried spd they sent one that's not even close, Will try Neil&Parks .
http://www.stainlessheaders.com/flanges
Or, http://bendtubing.com/index.php Im not sure if he makes flanges. But itll be worth the call. He's very reasonable.
Steve Tucholsky |
#7 | |
Jim. I can AutoCAD and have them Laser Cut out of stainless or Mild Steel P&O. Do you have a Header Gasket? If so message me and I will give you my address and I will quote this for you
________________________ Tim Takash Super Stock 248 |
