Old 01-19-2015, 02:36 PM   #1
Gerry
Default Ceramic lifters
Curiosity question. Are ceramic type lifters still being used
by Stock Eliminator guys? If so, what do they cost ?
Thanks in advance,
Gerry
Gerry is offline   Reply With Quote
Old 01-19-2015, 03:30 PM   #2
ron mattson
Liked 67 Times in 30 Posts
Default Re: Ceramic lifters
Yes and approx 900.00 pr set
Ron Mattson 5015 STK
ron mattson is offline   Reply With Quote
Old 01-19-2015, 07:53 PM   #3
GTX JOHN
Liked 2,487 Times in 698 Posts
Please be aware.......We have had the bottom fall out of a couple
of sets and destroyed engines. Be careful with valve adjustment and
watch valve train.
John Irving
741 Stock
741 Super Stock
Old 01-20-2015, 12:36 AM   #4
D. Hake 4459
D. Hake 4459's Avatar
Liked 2 Times in 1 Post
Some people are still using the Smith/Schubeck style lifters but as was previously stated if one breaks the short block is toast. A lot of people are now using Trend or PPPC tool steel lifters, limited travel for hydraulic cams.. If you're using a billet cam you have to use the coated ones. The only draw back with tool steel lifters is you can't break the cam in with them. You have to use standard lifters with reduced spring pressure or Smith/ Schubeck lifters to break the cam in.
Derek Hake 4459 H/SA 69' Roadrunner
D. Hake 4459 is offline   Reply With Quote
