Old 01-19-2015, 12:05 PM   #1
Greg Reimer 7376
Liked 719 Times in 220 Posts
Cool Chevy oil filter adapter
Recent thread here dealt with the engine that ate a wire snap ring and it cut a main bearing pretty badly and obviously went through the oil pump. Mention was made about blocking off the oil filter bypass valve in the filter adapter. How are you guys doing that,or does our burgeoning aftermarket parts industry manufacture such a unit for '68 up blocks, and '67 on back small journal engines? I have plenty of both in my garage and store room.
As far as past history goes, in the mid '70's, I worked as a mechanic in a Chevy dealer,and a 66-67 SS396 4 speed Chevelle came in on the hook-no oil pressure. To complicate matters, it had a scatter shield,headers,and was are beast to work on. The engine had to come out to pull the pan. Inside the pan was at least a dozen wire ring lifter snap rings. Also, the pump and pickup were broken off the rear cap and laying in the sump of the pan. The customer was lucky and shut the engine off in time not to damage it. Pump was locked up solid. Service writer didn't want to take the time to sell the customer a correct job and fix it right, so we put a pump,pickup,and intermediate shaft in it, cleaned out and reinstalled the pan, fired it up, it had pressure and they let it go. It should have had a set of lifters,push rods and valve springs replaced in it as well.Nothing like good customer service and taking the time to do it right. That's why I haven't worked on cars for the public since 1980.
Old 01-19-2015, 12:46 PM   #2
Bob Gullett
Bob Gullett's Avatar
Liked 507 Times in 116 Posts
Default Re: Chevy oil filter adapter
I plug mine off. It saved my engine a couple of times when I used to run Gibbs oil my filter plugged up with the sludge created by that oil and when I fired up my car in the morning it had no oil pressure. If I didn't plug it I would of made a run not knowing it was plugged. You can take a OEM one knock out the valve and use a 1/4 pipe tap and install a 1/4 in pipe plug. Or use one of these.http://www.competitionproducts.com/C.../#.VL0_HuktHDc
68 Chevy11 327 F/S
Bob Gullett is offline   Reply With Quote
Old 01-19-2015, 12:56 PM   #3
Dragsinger
Liked 99 Times in 60 Posts
Greg,
Canton # 22-570 or Moroso # 23775 as examples, other companies sell an equivalent.
Larry Woodfin 471W
Old 01-19-2015, 04:20 PM   #4
Jim Caughlin
Liked 805 Times in 245 Posts
Bob,
Sorry to change the subject but I have the same issue with significant sludge buildup with the Gibbs oil. Is this a common problem?
Jim Caughlin
SS 6019
Jim Caughlin is offline   Reply With Quote
Old 01-19-2015, 04:32 PM   #5
Bob Gullett
PM sent.
68 Chevy11 327 F/S
Old 01-19-2015, 05:36 PM   #6
63corvette
Liked 359 Times in 103 Posts
Which Gibbs oil are you having trouble with?
I use a mix of the XP3 and XP9 and have not had an issue YET...
Should I begin to worry?
Thanks
Rick Cates
63corvette is offline   Reply With Quote
Old 01-19-2015, 05:39 PM   #7
Bob Gullett
It was the XP1.
68 Chevy11 327 F/S
Old 01-19-2015, 08:13 PM   #8
Greg Reimer 7376
Cool Re: Chevy oil filter adapter
A local racer showed us a cell phone pic of Gibbs oil as it came out of an engine. Remember late 50's FE Ford motors that had been run on Pennzoil? Looked pretty similar.I could see that could clog a filter.
Old 01-19-2015, 08:55 PM   #9
Bob Gullett
We used to run the Gibbs oil in our spare superstocker engine. This is a picture of the pan with 10 runs since the pan was installed clean.
68 Chevy11 327 F/S
Old 01-19-2015, 09:08 PM   #10
HandOverFist
HandOverFist's Avatar
Liked 33 Times in 16 Posts
Reminds me of old Quaker State 40 years ago.
Rich Taylor
I/SA - 321
