Old 01-18-2015, 11:31 AM   #1
Bruce Noland
Liked 444 Times in 145 Posts
Default Chev and Buick Parts and some additional items
350/270 Chev Short Block - Coated CP pistons, Total Seal Rings, Bushed Lifter Bores with Schubeck Lifters, Bullet Cam, Chev rods, Electric Water Pump, Balanced by Bub. 10 runs total. $1,750.00.
350/270 Chev Short Block- Ross Pistons, Total Seal Rings, Bushed Lifter Bores (no lifters), Good Bullet Cam, Bub Whitaker blueprinted and assembled piece. This block has a small repair but was running strong when I changed to another combination. It set the J/SA record at 11.29 a few years ago. It should be freshened but slap some parts on it and run it if you wish. $950.00.
350 Chev Bracket Long Block, Lunati Stroked crank (.013), 993 heads with 2.02 Valves, everything except manifold, carb, distributor. Ran 11.70's in a 3,450 pound car. About 30 runs since it was built. $1,250.00.
Original BB Chev Aluminum High Rise Intake, Cut Plenum, Great Condition $325.00
Large "school bus" Oil Pan for BB Chev. Cleaned, with Oil Trap and Painted. $275.00.
Buick 455 Block, Cleaned, Magnafluxed and deburred. It's meant to be the best of the 455 Blocks. $375.00
Buick Heads for 455, Cleaned and Magnafluxed. Not sure of their value. PM me about these. Also have new Stainless Valves for these heads.
2 Moroso 24 x 15 tires. 10 passes. $150.00
ATI Balancer for 350 Chev $175.00
Two Metric Converters. One PTC and One Dynamic. $225.00 each.
Complete High Desert Fuel Analyzer kit. Great condition. Cost $495 new. Now $275.00
B&M, Pro Bandit Shifter with Forward and Reverse Shift Plates for 3 Speed Transmissions and one plate for a Glide, Two different length shift Cables. Ten Passes Total. Beautiful Aluminum piece. All together this kit cost $600.00. Now $325.00.
Weld Wheels, Aluma Star,10x15 with 3 1/2" back spacing, GM Bolt pattern, nearly new. Mounted slicks on them but they did not fit my car. They were never on the ground. About $800.00 new. Now $425.00.
All prices exclude freight.
Thanks
Bruce Noland 1788 STK
Old 01-18-2015, 12:28 PM   #2
Daran Summerton
Daran Summerton's Avatar
Liked 66 Times in 37 Posts
Default Re: Chev and Buick Parts and some additional items
I will take the Dynamic please.
72 cutlass
Daran Summerton is offline   Reply With Quote
