Old 01-10-2015, 04:03 PM   #1
dborror
Default Oil pan heaters
Any pro or cons on using a oil pan heater.I run a sbc altered on alky. Im thinking about using one between rounds or when the car sits overnight at the track.Any trouble with oil sluging in the bottom of the pan.
dborror is offline   Reply With Quote
Old 01-12-2015, 11:18 AM   #2
DIAPERMAN
Liked 21 Times in 6 Posts
Talking Re: Oil pan heaters
If you ever plan on running a diaper put an internal heater in.
DIAPERMAN is offline   Reply With Quote
Old 01-13-2015, 12:30 PM   #3
dborror
Default Re: Oil pan heaters
Thanks I was getting ready to buy one in 2 months.
Old 01-14-2015, 06:23 PM   #4
Bill Baer
I run methanol And I have a Moroso heater in the pan and two block Heaters in the block. You'll really appreciate them when the temp drops below 60 degrees I can plug them all in and get the motor up to 100 degrees in about 1/2 hour. They also shorten the warm up time as well.
I have had no problems with oil sludging in the pan but I've never left them on overnight.
If you put a vacuum pump on it you can eliminate the "milking up" the oil too.
