Old 12-30-2014, 07:43 PM   #1
Jeff Stout
Liked 704 Times in 281 Posts
Default Setting valve spring heights?
When setting valve spring heights for example all springs set at 1.90. Do you set them that way or based off of difference from intake to exhaust lifts. Say 500 intake and 480 exhaust. Do you ad 20 to the install height of exhaust spring to make it even pressure wise against cam. Or is there more to it then that?
