Liked 99 Times in 49 Posts
Anyone running off set pins in their pistons,and how much.?Do you feel that theirs any power in it.
Liked 6 Times in 2 Posts
Jim I didn't see any difference. Used whatever offset Patterson sent. It was a PITA when I had to replace a couple of pistons.
Mike Semeniuk 632 GTMA |
Liked 9 Times in 8 Posts
Depends upon how thick the cylinder walls are....if its friction your trying to reduce I think the coatings available take care of that.
If you have a thinwall block (like most fords) that you got carried away with, with the boring bar, you can take some pressure off the major side by offsetting the piston pin to the minor side and, some say its easier to "rotate" the crank as with all non standard mods...your mileage may very |
Liked 10,647 Times in 2,207 Posts
If the pin is offset, would it cause the piston rock and break ring seal due pivot point placement?
Well I am not sure about that Larry some pretty well known engine guys say to run them
Liked 328 Times in 176 Posts
Offset pistons-----small amount of power there--- because of less power need to overcome rod load and easier crank rotation--- it makes engine RPM quicker---FED 387
Liked 772 Times in 192 Posts
Liked 1,535 Times in 572 Posts
Dwight is correct.
Piston offset reduces friction and cylinder wall loading; it also improves geometry. ![]() F1 and NASCAR has been doing it and also using guided pistons. Would not be surprised if Pro Stock is doing the same, especially with the use of short deck blocks. |
Liked 238 Times in 113 Posts
Depends on which way the offset is. Factory offset is to quiet piston noise.
Is the piston balanced in the center or on the center line of the off set pin placement? Just wondering about inertia.
