Old 11-23-2014, 03:19 PM   #1
Lee Valentine
Liked 319 Times in 68 Posts
Default LT-1 Heads
How do you install LT-1 heads on a bow tie block in SS Is welding required or is there a way to do it with a bypass hose? Thanks.
Lee Valentine 1661 STK
Old 11-23-2014, 06:45 PM   #2
Ed Wright
Ed Wright's Avatar
Default Re: LT-1 Heads
Lee, there are two plugs welded on the deck, oblong shaped. Then the pipe plugs on the front end of each head are drilled and tapped larger for water hoses. I can try to get you pictures of mine if you like.
Ed Wright 4156 SS/JA
Old 11-23-2014, 06:58 PM   #3
Lee Valentine
Ed, would like pictures if possible. My e mail 1661stock@gmail .com Thanks.
Old 11-28-2014, 11:31 AM   #4
Ed Wright
Ed Wright's Avatar
Sent.
Old 04-23-2015, 03:02 AM   #5
casrak7
Liked 3 Times in 2 Posts
Hi Ed......Could you send me pics of this also? Thankyou much!
casrak7 is offline   Reply With Quote
Old 04-23-2015, 01:31 PM   #6
Ed Wright
Ed Wright's Avatar
Give me your email. Or I can text it if I had your ph #. Send me a pm.
Old 04-24-2015, 09:41 PM   #7
Ed Wright
Ed Wright's Avatar
Get the second picture too?
Old 04-24-2015, 10:07 PM   #8
casrak7
yes....those attach to the lower radiator hose? where do i get such a fitting?
Old 04-24-2015, 11:05 PM   #9
Ed Wright
Ed Wright's Avatar
Upper hose, which is on the driver's side. Lower hose, from the water pump, goes to the bottom of the passenger side of the radiator. I Tig welded mine together from a piece of 1 1/2" exhaust tubing, a piece of steel plate to cap off one end, and steel -10 AN fittings Tig welded to it. Those two -6 fittings on top, that are capped, are not needed.
Old 04-26-2015, 08:21 AM   #10
Lee Valentine
Did mine like Ed did his,works fine.
