Old 11-21-2014, 11:56 PM   #1
69camz28
Default 69 Camaro Power to Manual Steering
I have a 69 Camaro with a power steering box. I'm interested in converting this to a Manuel steering setup. Can anyone help me with what is needed and suggest vendors who have quality parts? Thanks in advance....Jeff
69camz28 is offline   Reply With Quote
Old 11-22-2014, 07:52 AM   #2
Greg Barsamian
Liked 419 Times in 96 Posts
Wink Re: 69 Camaro Power to Manual Steering
Contact The "Lil" "Drummer Boy" Jerry MacNeish
Jerry forgot more about Camaro's than most know!
http://z28camaro.com/wp/contact-info
Old 11-22-2014, 08:27 AM   #3
Cdncarnut
Cdncarnut's Avatar
Liked 56 Times in 31 Posts
Default Re: 69 Camaro Power to Manual Steering
I did this with a Z28, which I had 10 years ago.
All I needed was a Standard Steering box, of which I had a couple on the shelf and a Quick Ratio Pitman Arm, which I found on E-Bay.
Check out this page,
http://www.camaros.org/suspen.shtml#steer
Hope this helps.
Thomas
NHRA 1959 D/SA
Cdncarnut is offline   Reply With Quote
Old 11-22-2014, 07:37 PM   #4
chris ok
chris ok's Avatar
Liked 46 Times in 29 Posts
I have an additional question on the answer.
Do you need to find a correct corresponding idler arm to match the new pitman arm to keep center link level and centered?
Chris
chris ok is offline   Reply With Quote
Old 11-23-2014, 09:24 AM   #5
Cdncarnut
Cdncarnut's Avatar
Chris
It depends on what is in the car now.
If you are only changing from power to manual steering and are not changing from quick ratio to standard or vice versa, you do not need to change the idler arm.
That is why using the correct pitman arm is important.
Thomas
NHRA 1959 D/SA
Old 11-23-2014, 09:42 AM   #6
Adger Smith
Liked 880 Times in 311 Posts
I had a 69 Z that I did the change on. I pulled everything from a 1967 6 cyl Camaro. I took from spindle to spindle. The drag link was smaller diameter and the complete assy weighed less. I would think twice about the quick steering on a drag car. I always use the slower steering rack & pinions in cars I build. Think about it: Quicker steering might cause a driver to over correct during a problem run. I've see more crashes where drivers over correct than crashes where they don't correct enough. Just my .02 for free!
Adger Smith (Former SS)
Old 11-23-2014, 12:31 PM   #7
69camz28
Thanks, guys. I emailed with Jerry as suggested. That, along with what I read here, says get the manual box and the pitman arm....if anyone else has anything to add please feel free to add! Thanks again, Jeff
Old 11-23-2014, 05:09 PM   #8
69camz28
Also, how much weight difference between the power and manual setups?
Old 11-29-2014, 12:31 AM   #9
1700camaro
Liked 226 Times in 115 Posts
If you go to the Borgeson website it list the weight between the different steering boxes.
1700camaro is offline   Reply With Quote
