Old 10-06-2014, 10:20 AM   #1
rick978
rick978's Avatar
Default Bad racing fuel ?????
i need help with this one . we tested fri night with our 90 mustang n/sa with some changes made pro m maf 70mm with 24lb cal and ford racing 24lbs .and no spacer between plenum . cold night and rain is on the horizon. car ran first pass with good burnout 13.1 .came back bumped timing up a little added fuel we had from last time out (2 weeks ago vp 110 oct) . diff lane not too much of a burnout car went sideways out then ran a 13.9 almost same mph @ 100 came back took timing out a little timing out added new fuel (just purchased )to top cell off car took off to staging and did a burnout then fell flat on its face when light went green .limped down track did not want to idle also would rev then die on idle set timing back went up again and died in staging . since then we put everthing back to previous setup . still wont idle also exh does not have same smell (race fuel smell) gas guy had just ran out of 110 and opened a new 55 gal for us i am pretty sure it did not have any color to it after checking everything we can the fuel is next to looked at .going to drain cell and look to see if it has the purple color and smell of 110 vp fuel . has anyone ever had this happen to them ? maybe bad 55 drum ??or am i over looking the obvious . someone also mention that the royal purple oil might have washed the cyl out and we now have low compression ?thanks any info we vcan try will be helpful heres a little info on car
90 stang stk elim n/sa c4 auto 4.56 gear 30 x 9. 15 hoosiers a9p computer egr delete no ps alt only elect pump msd dist and box and wires car starts but stumbles at low rpm can rev and hold high idle exh smells a little rich and weird also plugs are light brown
rick978 is offline   Reply With Quote
Old 10-06-2014, 10:41 AM   #2
Dave Ribeiro
Liked 56 Times in 27 Posts
Cool Re: Bad racing fuel ?????
Rick,
I had some problems with VP-110 a couple of years ago ... It's only go for testing, NHRA doesn't have it on the approve list !!! IHRA , does the last time I checked ?? The VP-110 is a mix of left over race fuels & does funny things to the plugs + tune-ups ... I finally changed to Sunoco 110 & now they are having problems passing NHRA checks ... I finally went to C-12 and it passes every-time ... The dollar or two difference isn't worth the time & money we spend to go to NHRA races !!!! LOL?
Dave Ribeiro 1033 STK
Old 10-06-2014, 10:55 AM   #3
rick978
rick978's Avatar
Default Re: Bad racing fuel ?????
can that fuel be purchased outside of the track /speedshop or on line ?
Old 10-06-2014, 11:46 AM   #4
Myron Piatek
Liked 138 Times in 51 Posts
Post Re: Bad racing fuel ?????
With Sunoco becoming the official fuel of NHRA, there should be less issues with fuel check and it should be available at the track as well. But they do have an extensive distribution network if you want to get it before a race.
http://www.nhra.com/story/2014/5/5/s...icial-sponsor/
http://racegas.com/fuelfinder
LOCOMOTION Racing
Old 10-06-2014, 01:54 PM   #5
Mike Taylor 3601
Mike Taylor 3601's Avatar
Liked 319 Times in 108 Posts
No matter who's fuel I use,when I pump from the barrel I don't stick pump to bottom of barrel in case there is any water and that is always possible.
They may pumped off bottom of barrel and you got mixture of water and gas
Mike Taylor 3601
Old 10-09-2014, 12:55 AM   #6
CFMCNC
A good investment for the trailer is a Specific gravity tester,Computech has a fair priced one.One way to tell if the fuel is going bad is by weight as bad fuel often will weigh heavier .Bill C.
CFMCNC is offline   Reply With Quote
