Old 09-25-2014, 11:56 PM   #1
Dave Noll
Dave Noll's Avatar
Liked 240 Times in 112 Posts
Default 351c Cam Timing Question
Before I have a smaller cam ground I want to exhaust my options on this big one. The cam card says that the int. open's .050 @ 23' BTDC installed @ 102 int CL. Currently this happens @ 24 BTDC. (101 cl ?) If I advance this 4' that would be 28 BTDC. If I understand right that would be 97 int CL. I dealing with a low power problem. ........... 97 just seems way out there to even try. Application is 1972 351c/240hp 2bbl. Comp ground the cam. Input/ideas.
Dave Noll, EF/S ,?/SA 6526
Old 09-26-2014, 09:49 AM   #2
Hans Olsson
Hans Olsson's Avatar
Default Re: 351c Cam Timing Question
110 intake lobe centerline in our 351 C. 1972 275/325 hp HO
Hans Olsson is offline   Reply With Quote
Old 09-26-2014, 10:04 AM   #3
astikhossw
astikhossw's Avatar
Liked 20 Times in 9 Posts
It's not out there if you are trying for some lower rpm torque.,you may as well try it then you will know you can always put it back if you don't like it.
7015 E/SA Sooner Storm
astikhossw is offline   Reply With Quote
Old 09-26-2014, 04:08 PM   #4
Dave Noll
Dave Noll's Avatar
Sooner, thanks for the reply, It's reassuring. Hans, is that where the cam is installed @ or what the cam grinder ground it to ?
Old 09-26-2014, 05:24 PM   #5
Hans Olsson
Installed at 110, ground at 102.
