Old 09-23-2014, 09:01 AM   #1
njk53
Default Determining Spring Rate
How do you determine what spring rate would be the correct application for your race car? We are looking at replacing our front springs due to a fair amount of corrosion in the area of the spring where it sits in the lower control arm pocket. I noticed in the Jeg's catalog that Moroso has a specific spring rate for an application based upon whether the car is a big or small block along with the the total front end weight. Is this an acceptable way of determining which rate spring you need or are there other factors involved?
Nelson Kowal
Stock 345
