Old 09-18-2014, 08:45 PM   #1
Karl Owens
Default LT1 Block Options?
Is there a way of using a good block with the LT1 reverse cooling heads?
NHRA Stock/Super Stock 1078
Karl Owens is offline   Reply With Quote
Old 09-18-2014, 09:06 PM   #2
BillK
Liked 30 Times in 17 Posts
Default Re: LT1 Block Options?
Karl,
I am sure you could do it with a little creative plumbing. I have 4 LT1 blocks in the shop right now so I will try to take a look at one next to a traditional 350 block and see what might be do-able.
Bill Koustenis
BillK is offline   Reply With Quote
Old 09-18-2014, 09:20 PM   #3
Rich Biebel
Rich Biebel's Avatar
Liked 557 Times in 217 Posts
There were some Bowtie LT-1 blocks made by GM. Probably near impossible now to find one but they did make them and I took delivery of 1 for someone else.
They made them in std bores and some with a 4.125 bore
I think that some engine builders probably were able to modify a std Bowtie block to work.....
Rich Biebel
S/C 1479
Stock 147R
Old 09-18-2014, 09:40 PM   #4
Karl Owens
All LT1 stockers out there running OE blocks? 4.080?
Old 09-18-2014, 10:28 PM   #5
1legjerry
Liked 72 Times in 15 Posts
Can you use the LT(gen 2) block cam and lifter in the Gen 1 blocks?
1legjerry is offline   Reply With Quote
Old 09-18-2014, 10:37 PM   #6
Karl Owens
Yes you can as long as there is provisions for the cam retainer plate
