Old 09-11-2014, 03:29 PM   #1
John Nechiporchik
Liked 13 Times in 7 Posts
Default Metric 200 Flex and Trans shield
What are the best choices for Metric 200 flexplate and trans shield in a 98 F-body stocker? The trans also has a stabilizer bar mounted on the passenger side. Real estate is pretty tight in this car.
Thanks for input.
John Nechiporchik is offline   Reply With Quote
Old 09-11-2014, 06:54 PM   #2
Tony Goodman
Liked 18 Times in 4 Posts
Default Re: Metric 200 Flex and Trans shield
John, I got my trans shield from Tom Waters Race Products. The trans dipstick I use is a Lokar with the firewall mounting style. Tony
Tony Goodman is offline   Reply With Quote
Old 09-11-2014, 07:22 PM   #3
ss3011
ss3011's Avatar
Liked 239 Times in 114 Posts
Might want to check out Scott McClay's website, for a trans shield that is compatible with the brace.
http://www.scottmcclayengineering.co...nsmission.html
Flexplate from ATI will have the correct bolt pattern, it is the same for a PG/200/350/400 THM for a sbc.
Old 09-11-2014, 08:08 PM   #4
John Nechiporchik
Thanks Tom and Russ.
Tom, I noticed your Lokar mounting location when I looked at your car Sunday.
I got the same unit with my trans.
I'll check out the info you both suggested.
Thanks.
Old 09-11-2014, 08:16 PM   #5
John Nechiporchik
To clarify, I was asking about a flexplate shield and a trans shield. I already have the flexplate.
Thanks.
Old 09-11-2014, 09:42 PM   #6
Bob Mulry
Bob Mulry's Avatar
Liked 320 Times in 102 Posts
Flex plate and flywheel shield in Stock??????????
Just asking..........
Bob
Bob Mulry 7516 STK
A & M Motorsports
Old 09-12-2014, 08:34 AM   #7
John Nechiporchik
The way I understand it, 10.99 or quicker requires trans and flexplate shields.
If it's something different, someone please help clarify.
Thanks
Old 09-12-2014, 09:02 AM   #8
John Nechiporchik
I just reviewed the rulebook ....again.
In the Stock section, there is no reference to a shield for trans or flexplate.
In general regs. section 2.14 it says that a trans shield (SFI 4.1) required in 10.99 or quicker. A SFI 29.1 flexplate and SFI 30.1 flexplate shield is required for 9.99 or quicker.
I hope I got this right!!
Old 09-12-2014, 09:14 AM   #9
Greg Hill
Liked 279 Times in 68 Posts
I don't think stock eliminator cars that don't run in the 9's have to have the shield.
Greg Hill 4171 STK
Old 09-12-2014, 09:38 AM   #10
HandOverFist
HandOverFist's Avatar
Liked 33 Times in 16 Posts
Not a class requirement in Stock and the exception is noted in general regulations.
Rich Taylor
I/SA - 321
