Old 09-07-2014, 11:49 AM   #1
JWagner
Liked 17 Times in 4 Posts
Default GM 8.5 mini spool
Anybody run a mini spool in a 8.5 GM rear end? Will they survive in a low horsepower stocker?
JWagner is offline   Reply With Quote
Old 09-28-2014, 08:30 PM   #2
Bob Shaw
Liked 323 Times in 63 Posts
Default Re: GM 8.5 mini spool
They are recommended for dirt track cars only. I don't know why.
Bob Shaw V/SA 515
Bob Shaw is offline   Reply With Quote
Old 09-28-2014, 10:42 PM   #3
J,
A posi-traction will survive in a low hp automatic Stocker. I don't see why a mini spool wouldn't.
Old 10-04-2014, 09:50 AM   #4
cad
cad's Avatar
Liked 93 Times in 52 Posts
I believe a mini spool is not legal in NHRA. You are also required to have aftermarket axles when running a spool.
Old 10-10-2014, 02:07 PM   #5
Ron Middleton
Liked 12 Times in 4 Posts
When I bought my H or J/SA 1980 Camaro it had a mini spool in it and had hundreds of passes on it without failure.
#4892 J/SA. We are what we repeatedly do. Excellence then, is not an act, but a habit.”
- Aristotle
Ron Middleton is offline   Reply With Quote
Old 10-10-2014, 02:37 PM   #6
pbp1
Liked 27 Times in 6 Posts
It may last, but it is more prone to failure because with a mini-spool, all the load from the ring gear to the axles is transmitted only through the pin, to the bore in the cast case. With a posi unit, most of this load is transmitted through the clutches, into the inside of the case.
pbp1 is offline   Reply With Quote
Old 10-10-2014, 04:02 PM   #7
55 zimm
I ran a 8.5 ten bolt mini spool in a 87 firebird 3200 lbs bracket car. the car ran 11.17 122mph 1/4 mile 7.08 99mph 1/8 mile with a trans brake. We had over 100 passes at those time with no problems. I would not say that they are bullet proof but if you foot brake with low hp it should last a long time.
55 zimm is offline   Reply With Quote
