Old 09-02-2014, 03:10 PM   #1
67chevygary
Default Anyone attending VanDerBrink auction?
If anyone is attending this auction in Grant Ne. would it be possible to inspect the 2X4 air cleaner-item #48b I need to know the measured distance between the carb mounting holes and if there was an extra hole drilled outside of the normal hole which should be in the indentation on the top of the air cleaner. thanx and good luck.
67chevygary is offline   Reply With Quote
