Old 08-31-2014, 05:53 PM   #1
Paul Neal
Paul Neal's Avatar
Liked 3 Times in 1 Post
Exclamation Dan Page 250" Swing Arm Dragster Rolling $15500.00
2006 Dan Page Swing Arm Dragster
250" Wheelbase - 21" Cage
Updated Winter 2011/2012
Current NHRA 2.5B/6.00 Certification
Less Engine/Transmission
$15,500.00
Includes:
Mark Williams Econo Rear End Housing and axles
Bolt-through MW Aluminum 3rd Member
35 Spline Aluminum Spool w/large pinion 4.30:1 Gear
Mark Williams Brakes
Mark Williams 3.5" Dia Aluminum Driveshaft
Ceramic Axle Bearings
Weld 16"x16" Alumastar Wheels w/ no screw holes
Good Year 33.5X17-16
Weld Alumastar Fronts w/sealed roller-type bearings
Good Year Front Runners
AFCO Double Adjustable Shock w/Remote Canister
Chrome Mono Wing Stand (wing NOT included)
Carbon Fiber Suspension Cover
Transmission Limiters
Aluminum Front and Rear BBC Engine Plates
Ron Davis Radiator w/ Fan & Mount
Chrome Aluminum Deflector Plate
Carbon Fiber Interior & Seat
Carbon Fiber Dash for Racepak UDX or IQ3 Display (Display NOT Included)
Carbon Fiber Dash Cover
Stroud 5 Point Harness
Racepak V300SD Mount (Racepak NOT Included)
Carbon Fiber Wiring & Accessory Tray
MSD 7530T Ignition
Dedenbear CC-1
Painless Switches
B&M Pro Bandit Shifter - Air Operated
Weldon 2025 Fuel Pump
Kinsler Fuel Filter @ Pump
3+ Gal Front Mount Aluminum Fuel Tank
Master Disconnect w/ Rear & Drivers Cockpit Push/Pull Handles
Chrome Dewzen Dial In Board Mount
Chrome A Arms & Steering Arms
Contact info: 617-771-9725 nealjp@comcast.net pneal_sc119e@yahoo.com
Paul Neal 119E TD/SC
Dan Page 265" w/ Martin 632
6.490 @ 205.76 ...all motor!
Paul Neal is offline   Reply With Quote
