Old 08-27-2014, 08:28 AM   #1
richie 2
Liked 205 Times in 93 Posts
Default leaky heads studs/nuts
couple slightly seeping @ the nut. any remedies?... please/thankyou.
Old 08-27-2014, 09:35 AM   #2
tj310
Default Re: leaky heads studs/nuts
http://classracer.com/classforum/sho...ing+head+studs This should help. ---Trevor
Old 08-27-2014, 09:36 AM   #3
SSDiv6
You can use any of the following Loctite products:
Loctite 518
Loctite 51813
Loctite 51818
Apply to the threads, let it dry and re-assemble..
Old 08-27-2014, 02:00 PM   #4
Bob Mulry
Bob Mulry's Avatar
Liked 320 Times in 102 Posts
We always used the GM brown sealer in the can with the applicator attached to the cap....
It looked like Permatex Aviation Form-A-Gasket only thicker.....
Nasty stuff but it worked great on studs and bolts..........
Bob
PS:
Don't forget to add a good block sealer such as Moroso Ceramic Block Sealer or K & W Metallic Block Sealer
Bob Mulry 7516 STK
A & M Motorsports
Old 08-27-2014, 07:49 PM   #5
BillK
Liked 30 Times in 17 Posts
Richie,
Always found that on studs it helps to actually put some of the sealer in the threaded hole first. Not sure why it works, never do it with bolts ? If you are fixing it without pulling the head, pull the stud completely out, get some sealer down in the hole with a screwdriver or something and then thread the stud back in.
Bill Koustenis
BillK is offline   Reply With Quote
