Old 08-18-2014, 02:02 AM   #1
Rory McNeil
Liked 1,104 Times in 302 Posts
Default Strange truck/trailer electrical problem.
Earlier this year I replaced my old ramp truck with a F350 dually and 24 foot Wells Cargo trailer. On Saturday morning I was all loaded up for a race, but when I was ready to leave home, as soon as I turned on my trucks headlights, the red light on the brake controller came on and the trailer brakes were engaged. Turned the lights off, and the truck would move, turn the lights on, and the trailer brakes locked up. When I unplugged the trailer harness from the truck, the controller light went out, and the brakes were released. I have used the truck and trailer before with no issues, so it can`t be anything wired up wrong, but I`m guessing power is being fed back thru the electrical system. Anybody experianced this before?
NHRA 6390 STK
M/S 85 Mustang
Old 08-18-2014, 04:03 PM   #2
Painter
Liked 162 Times in 45 Posts
Default Re: Strange truck/trailer electrical problem.
More than likely your trailer has been grounding thru the hitch ball. Trailer sat awhile without being hooked up and some corrosion formed in the coupler and on the ball. Most strange electrical problems when you first hook up can be traced to bad grounds between the truck and trailer.
Painter is offline   Reply With Quote
Old 08-19-2014, 12:23 PM   #3
drgrcr1156
Liked 2 Times in 1 Post
Another area to lock is the 7-way plug. Look for corrosion tracing between the terminals.
drgrcr1156 is offline   Reply With Quote
Old 08-19-2014, 12:37 PM   #4
FED 387
Liked 333 Times in 180 Posts
CHECK the wiring to make sure you have the wires in the correct position in the trailer plug in relation to the truck receptacle--- look inside the cover flap on the truck and it will give you the position number and the wire color for each position make sure it matches the trailer pattern--- some use the RV pattern and others may have used the commercial truck wiring pattern--- also if your truck is over about 10 yrs old the factory wiring receptable is probably corroded inside & you can get a replacement unit on ebay for less than $10--- my experience on this!!!!---FED 387
Old 08-19-2014, 05:33 PM   #5
voltdr
Liked 100 Times in 51 Posts
Most all "strange" electrical problems come from bad grounding. I always recommend running a separate ground wire for the trailer wiring and not rely solely on the hitch to make the ground.
Dan
voltdr is offline   Reply With Quote
Old 09-17-2014, 04:54 PM   #6
buzzinhalfdozen
Liked 11 Times in 8 Posts
My son just had a similar issue with his rig...only when he turned his ignition on the trailer brakes would apply (turning the ignition on makes the Aux. battery terminal hot in the 7 pin plug, at least on the fords) He unhooked the plug a few times and it stopped but I'm certain there's corrosion in either the vehicle plug or the trailer plug or both. The only other option is one of the 2 is miswired. If the truck has the factory 7 pin plug then that would be wired correctly, at that point I'd look closely at the trailer wiring. Good luck Joe BTW any modern enclosed trailer has a dedicated ground wire in it's plug...so grounding thru the ball is a thing of the past.
Joe Buchanan SS/BX 3117
Old 09-22-2014, 08:30 AM   #7
Wayne W
Wayne W's Avatar
Liked 3 Times in 1 Post
Poor ground.
Wayne W is offline   Reply With Quote
Old 09-22-2014, 10:59 AM   #8
Run to Rund
Liked 54 Times in 27 Posts
You might also check the trailer wiring where exposed for rodential munching.
