Old 08-13-2014, 11:15 AM   #1
supergas4
Liked 6 Times in 5 Posts
Default Inverter location Haulmark coach
I have a 06 Haulmark motorhome with a Xantrex inverter.where is the inverter most likely located.Thanks.Dwight Allen
supergas4 is offline   Reply With Quote
Old 08-13-2014, 11:42 AM   #2
FED 387
Liked 335 Times in 182 Posts
Default Re: Inverter location Haulmark coach
I would call Haulmark @ 574-264-9661 and have your model # handy they will be able to answer your questions. FED 387
Old 08-13-2014, 04:06 PM   #3
Rob Petrie E395
Liked 216 Times in 77 Posts
I have the same inverter but mine is in a Haulmark Toterhome. In any case mine is mounted inside one of the outside compartments on the drivers side.
Old 08-13-2014, 05:09 PM   #4
FED 387
Also "generally" they install them near the batteries cuts down on long cables and power loss---look in the basement lotsa times installed in a bin near the motorhome batteries-- first place I would look---
Old 08-13-2014, 06:51 PM   #5
supergas4
thanks guys im still looking but i will find it.
Old 08-13-2014, 07:03 PM   #6
Rob Petrie E395
Both of my Haulmarks have had the inverter on the drivers side and the batteries on the other side. But you never know.
Old 08-13-2014, 07:08 PM   #7
Rob Petrie E395
Do you know what it looks like? If you PM me a cell phone number I can send you a photo of mine.
Old 08-14-2014, 09:24 AM   #8
supergas4
THanks again folks .It was behind a drawer under hall closet I think they try to see how well they can hide them.
