Old 08-10-2014, 09:10 AM   #1
Pistol Pete
Pistol Pete's Avatar
Liked 816 Times in 215 Posts
Default Tow Vehicle Help
Need some help on a engine for my tow vehicle.
Current engine has 208,000 miles. It's a 6.0L GMC
What would be a good route to take ??
Anyone have experience with Jasper Engines ??
Not looking to spend a lot of money either....
Thank you.
"Pistol" Pete Dutko
Old 08-11-2014, 12:34 PM   #2
Tar Heel
Guest
Posts: n/a
Default Re: Tow Vehicle Help
What's it doing? Burning oil? Down on power?
If you can have the down time I would say the most economical thing to do IMHO would be to pull it and do a rebuild. Valve seals, springs, cam, lifters, hone, rings, bearings, gaskets, machine work, ... Sounds like a lot cheaper than a new engine. Might be a good time then to add a towing cam and converter while it's apart.
Scott
Old 08-11-2014, 01:10 PM   #3
pistol paul
try dilithium crystals in fusion reactor for impulse engine drive system
pistol paul is offline   Reply With Quote
Old 08-11-2014, 03:19 PM   #4
Rob Petrie E395
Liked 216 Times in 77 Posts
Whats wrong with it? Define "alot" of money. A jasper engine wont be cheap.
Old 08-11-2014, 05:34 PM   #5
Pistol Pete
I'm not sure what Jasper gets.
I was thinking No More Than $5,000. or is it going to be WAY more than that.
Then, probably should look for something with less miles.
How bout a junkyard motor with say 70-100 thousand miles ????
"Pistol" Pete Dutko
Old 08-12-2014, 09:10 AM   #6
Dave Ribeiro
Liked 56 Times in 27 Posts
Wink Re: Tow Vehicle Help
Pete, you have a PM............
Dave Ribeiro 1033 STK
