Old 07-30-2014, 12:28 PM   #1
dwg4859
Default wont rev
I have a 71 nova with a 278 hp 350 the car wint rev past 5200 on the track but does in burn out. i changed fuel pump and reg thinking it would solve it i raced sat and it didnt it has a hy cam with lifters with shims in them i set the valve lash at 0. where should i look next
thank you
dwg4859 is offline   Reply With Quote
Old 07-30-2014, 08:21 PM   #2
Mike Taylor 3601
Mike Taylor 3601's Avatar
Liked 306 Times in 103 Posts
Default Re: wont rev
have msd chip rev limiter take chip out,they will rev in water and shut off under load if bad.
Mike Taylor 3601
Old 07-30-2014, 09:01 PM   #3
dwg4859
i don't have msd i have a hei only, the fuel pressure Gage never drops below 5 psi, do i need a msd?
Old 07-30-2014, 09:57 PM   #4
bigfoot584
Also disconnect tach.
Change the HEI cap and rotor also, any HEI will work your
just testing to see if it runs fine, if it dose you can repair or
replace yours then, but that take the whole dist. out
loop completely.
No you don't need a msd if it ran before it'll run again (I don't need no stinking msd).
bigfoot584 is offline   Reply With Quote
Old 07-30-2014, 10:02 PM   #5
dwg4859
thankx i will
Old 08-06-2014, 07:45 PM   #6
stk1333
Had a similer problem,would only go 5000 in 1st gear,ok in 2nd and 3rd.changed pump,regulator,filter,cap,rotor and unhooked the tach(not all at once lol) changed the hei control module and it works perfect
stk1333 is offline   Reply With Quote
Old 08-07-2014, 08:05 AM   #7
jim powers
jim powers's Avatar
Liked 13 Times in 10 Posts
try 7 lbs. fuel pressure
jim powers is offline   Reply With Quote
Old 08-07-2014, 09:19 AM   #8
Todd Hoven
Guest
Posts: n/a
Need to look at that HEI module. I had one in a car I was trying to sell. It ran me through the ringer. I bought and tried 3 different modules before I bought an MSD replacement, and that fixed it. If you know somebody with a distributor machine you might want to take it there and have it checked out for yourself. I've heard GM had different part numbers for modules, and the ones that came in the HP cars were the ones to use.
Old 08-07-2014, 10:27 AM   #9
Jim Bailey
Liked 584 Times in 94 Posts
Cool Re: wont rev
Todd's right. You can actually have it tested at your local Auto Zone store. That's if you're lucky enough to find someone there that knows how to do it. But, "they do" have the machine.
Jim Bailey is offline   Reply With Quote
Old 08-07-2014, 11:38 AM   #10
Jacob Pitt
Make sure your secondaries are opening too. Don't ask me how I know about that. Hahaha
Family Tradition Racing
Jacob Pitt is offline   Reply With Quote
