Old 07-15-2014, 07:05 PM   #1
Straightliner
Default Time vs RPM?
I have a few questions. 1) Do I need to figure out my T stop ratio doing the, a lot of timer then a little timer and doing the math or can I just let Crew Chief do it using the Calculate ratios tab once I have some good runs? 2) I currently go on stop at .500 and come back off the stop while still in first gear and then shift to high at 6500 rpm. What I want to know is can I shift on time at the time it hits 6500 knowing that depending on timer 2 number that time would in fact be changing but I wouldn't actually change it to compensate it would just be what it is. Can I do it and be consistent? My thinking is that the time it takes to get to 6500 is also a changing time due to the timer 2 number so I think it will be fine but wanted opinions.
Straightliner is offline   Reply With Quote
