06-25-2014, 08:46 AM | #1 |
Liked 72 Times in 40 Posts
67 Camaro 396 alum hd- front end weight?
A friend has a 67 Camaro with a big block, alum heads, no ac, no ps.
He is ordering front drag coil springs and doesnt have access to scales. Any idea what the typical front end weight is? Thanks Clark |
06-25-2014, 11:41 AM | #2 |
Liked 33 Times in 16 Posts
Re: 67 Camaro 396 alum hd- front end weight?
Ours with an all iron 350 is 1604 pounds if that is of any help.
Rich Taylor I/SA - 321 |
06-25-2014, 01:08 PM | #3 |
I know what mine weighs with my SBC and alum heads per the scales. Still need a BBC/Alum head weight.
06-25-2014, 02:44 PM | #4 |
My guess would be 1700 - 1750 pounds depending on the intake used.
06-30-2014, 02:11 PM | #5 |
Liked 97 Times in 47 Posts
THE ALUIM HEADED rat motor should weight almost the same as a small blk with iron heads.
06-30-2014, 03:39 PM | #6 |
Liked 282 Times in 152 Posts
alum head bbc about 610---steel head 685---
07-01-2014, 08:13 AM | #7 |
Liked 726 Times in 177 Posts
Jim, when I switched my '67 from Z28 configuration to SS 396 configuration, the car picked up about 220 lbs. That was with iron heads. Aluminum heads are about 75 lbs lighter. I also switched from factory 4-piston disc brakes to drum brakes (-40 lbs.), but added the SS hood (+20 lbs.).
07-01-2014, 09:35 PM | #8 |
Liked 2,322 Times in 456 Posts
I don't know if this will help you. But when I changed my 69 camaro from a 350/255 hp stocker to a 396/375 alum head stocker I didn't change a thing as far as front springs. I always ran the Moroso super stock ones for a small block. In the end I had to change the rear springs because they were bending at the rear eyes. Barry
