Old 06-16-2014, 08:55 AM   #1
joespanova
Liked 13 Times in 11 Posts
Default Steel rod life expectancy
Anyone using steel rods to 9000 RPM (give or take) with 300 plus runs?
I lost a rod this weekend, ( Howards aluminum ) although the damage was basically just the block , 1 piston..........., Now I'll put a spare block into service and consider steel rods..............but , I'm not about to spend 3-4 grand on a set of Carillos.........no way. I'll go back to aluminum , possibly. I think any rod manufacturer that tells you their aluminum rods will see 300 runs in a combo like mine is full of shee-ot.
My fault / stupidity for running them past the 80 -100 runs ..........I should have chucked them a month ago........I'm a slow learner......... But my best guess is I didnt have more than 125 runs on those rods.
Small Chevy , 14.0 comp 6.150 rod.........so you can do the math , the piston isn't heavy.........
