Old 06-08-2014, 06:26 PM   #1
Tom keedle
Tom keedle's Avatar
Liked 8 Times in 7 Posts
Default sumpin' i learned yesterday (rt question)
I learned I hate LED bulbs in the tree.....
but somewhere between the last yeller and green I need to leave, not on the last yellow or as it turns green....I'm going red by a LOT...taller frt tires? 24" on there now...
more pressure in the rears? (8.5 X 26 slicks)? other ideas?
not running stock (yet) running a stickshift series this year but maybe you guys can give me some direction...
Old 06-09-2014, 01:17 AM   #2
Liked 5,080 Times in 1,936 Posts
Default Re: sumpin' i learned yesterday (rt question)
Change the ratio of the clutch linkage for more travel at the pedal.
Old 06-09-2014, 07:03 PM   #3
Myron Piatek
Liked 138 Times in 51 Posts
Post Re: sumpin' i learned yesterday (rt question)
Put on the tallest tires that will fit first. The longer rollout will help ET's as well as slow RT's a bit. Then adjust the clutch linkage like Mark described.
LOCOMOTION Racing
Old 06-09-2014, 09:11 PM   #4
Ed Wright
Ed Wright's Avatar
I have to use 28" tires, I can't imagine getting a green light with 24". What kind of car is this that you can use 24" tires?
Ed Wright 4156 SS/JA
Old 06-10-2014, 05:20 AM   #5
Tom keedle
Tom keedle's Avatar
67 American...
I don't think I can get 28" in the frt, probably 26's
I've got the freeplay completely out, helped the shifting a lot ,was having issues (stone stock used st-10 3.42 1st gear)
measured 'em again today 24.5"....
would have to trim the fenders for much taller...or raise the ride height
Old 06-10-2014, 01:47 PM   #6
Ed Wright
Ed Wright's Avatar
Stock tires on my Firebird were 25.7", so I started with 26". I didn't notice it going any faster after the 28"s, just more green lights. After hearing how taller fronts show faster on time slips I decided to A-B-A test that. (I wear my junk out testing) I borrowed a set of 26" fronts. Back-to-back-to-back testing showed about nothing. I understand the therory, but calling it one hundredth of a second difference on my car (which repeats very well) would be a stretch.
