Old 05-30-2014, 07:54 PM   #1
Slickfoot
Liked 2 Times in 2 Posts
Default Fox Body 5 speed to C4 convert.
I'm changing over my 89 Mustang from a 5 speed to C4 . I have a problem with the rear trany mount, It's a little to short to meet the cross member. Do I need a auto trans rear mount ? Help
thanks
Slickfoot
Slickfoot is offline   Reply With Quote
Old 05-30-2014, 09:26 PM   #2
partsbob67
Liked 79 Times in 11 Posts
Default Re: Fox Body 5 speed to C4 convert.
same cross member I think. to make it fit cut the welds on the mount sleeves so it slides and elongate the bolt holes. once you bolt it up just tack weld the sleeves.
bob beals 7244
partsbob67 is offline   Reply With Quote
Old 05-31-2014, 11:53 AM   #3
glen myers
glen myers's Avatar
Or Ford Racing part# M-5059-A is an adjustable one. Will solve your problem. Check driveshaft length you might be short- Steeda makes a very nice billet spacer that works great.
glen myers is offline   Reply With Quote
Old 05-31-2014, 01:39 PM   #4
Slickfoot
Thank you Bob, that worked like a charm. And Glen I thank you for your input allso , I was tipped off about the spacer and was ready.
Now I just need to get the shifter instulled and cluch cable and speed-o cable out, some wireing and we can get it to the track.
You can allways count on Class Racer people
Thanks
Slickfoot 3955
Old 06-03-2014, 09:33 PM   #5
Slickfoot
I need some help with wiring the park safety switch, were to tap in?
Slichfoot 3955
Old 06-10-2014, 10:53 AM   #6
Capri
Liked 27 Times in 14 Posts
We can sell you what you need. We stock the correct switch.
Capri is offline   Reply With Quote
Old 06-10-2014, 05:44 PM   #7
Slickfoot
Thanks for the reply Capri, but I used the clutch interlock wires. Just hard to get the wires out from under the dash with the rollbar there.
It's done and running, now having a problem with a flare going into 3rd. the trans builder says it's a qt. low on fluid. We will see.
Thanks for you for the help
Slickfoot
Old 06-10-2014, 06:33 PM   #8
dragracer9911
Liked 3 Times in 1 Post
Flair or Flash going into third is common, depending on who built the C-4. We switched from a C-4 to T-5 because of the flash because we felt the stick was quicker and more consistant. We got over 2800 runs with a stock T-5. We now have a used TKO in the car with 800 + runs.
dragracer9911 is offline   Reply With Quote
Old 06-10-2014, 10:30 PM   #9
Slickfoot
The flair seems to go away after the trans is warmed, or at higher RPMs
I also found the pan bolts loose. I don't think that has any thing to do with it. I'm going to put the qt. of fluid in it and try it. I have to put the exhaust back on to try it on the street.
Slickfoot 3955
Old 06-13-2014, 03:01 PM   #10
Capri
Cool. That works too. We stock the correct NSS to convert to a C-4.
The flare on the 2-3 is an issue in the clutch pack as I recall. If its not more than 200 rpm, it will work fine forever at 6500RPM. An extra qt may not help. I believe I have 7qts in mine with a deep pan.
