Old 05-21-2014, 05:03 AM   #1
rodrocket
Default Powerglide Shifter - Help
Greetings all
I am running a glide with a Hurst Pistol Grip Quarter Stick with the cable coming out the front of the shifter, I have clearance issues between the selector on the trans & the chassis rail of the car
I am thinking to go to a rear exiting shifter & run the selector lever on the trans upwards instead of down were it presently is & this should give me the clearance I require
any suggestions as to what stick to run, I need to be able to fit a CO2 shift solonide to it as well
regards
Rod
rodrocket is offline   Reply With Quote
Old 05-21-2014, 07:00 AM   #2
Liked 1,912 Times in 429 Posts
Default Re: Powerglide Shifter - Help
QuarterStick II.
Old 05-21-2014, 07:31 AM   #3
jmcarter
jmcarter's Avatar
Liked 3,227 Times in 981 Posts
Have always loved Paul Forte's shifter. Turbo Action is one of the few manufacturers that pays contingency (see their website or call Paul for details). You can also get different gates for fwd/reverse pattern, 2 or 3 speed and can convert it between fwd/reverse cable entry without anything extra to buy (changing the air cylinder from front to back at the same time).
Jim Carter
2340 Super Stock
2340 SST/2340 Stock
Old 05-22-2014, 08:53 PM   #4
Altronics
Sponsor
Altronics's Avatar
Liked 63 Times in 11 Posts
Check out our SHIFT product for your powerglide - no cables!
Fred Bartoli
847-923-0002
Altronics is offline   Reply With Quote
