Old 04-29-2014, 08:33 AM   #1
philbilly
philbilly's Avatar
Default May Day !! Down a cylinder
Alright class racer mechanics. I need some help. I am down a cylinder. Nber 7 keeps fouling plug. I have changed plugs wire cap dist. I did a leak down got about 1 percent leakage. Compression is 165lbs all cylinders I pulled the intake and fitted it last night.
I connected a plug to wire and it is firing at the cylinder.
The cam loves and lifters are fine.
Any idea?? There is several of us scratching our heads on this one.
I put 170 lbs air straight to cylinder it ha no leakage out valves
philbilly is offline   Reply With Quote
Old 04-29-2014, 08:47 AM   #2
Greg Reimer 7376
Liked 705 Times in 219 Posts
Cool Re: May Day !! Down a cylinder
Intake valve guide or seal on that cylinder. Sounds like a properly sealed engine. If the intake or heads were very mismatched, it would have affected other cylinders as well.
Old 04-29-2014, 08:55 AM   #3
Chuck Beach
Chuck Beach's Avatar
Liked 58 Times in 13 Posts
Send a message via AIM to Chuck Beach
Default Re: May Day !! Down a cylinder
Sounds like a leaky valve guide, you could put a little hotter spark plug in that cylinder to burn off the oil.
Chuck Beach
3340 STK
Chuck Beach is offline   Reply With Quote
Old 04-29-2014, 09:00 AM   #4
philbilly
philbilly's Avatar
Chuck we changed plugs and wires several times. I am thinking guide but if guide was wore it would show in leak down?
This is the new head we did fix. I busted one at gators.
Mb is gonna post up pic of plugs for me. I sent him pic of 1 and 7 plug so y'all could see
Old 04-29-2014, 09:03 AM   #5
philbilly
philbilly's Avatar
Running with a temp gun number 7 never gets within 200 degrees of other cylinders.
Old 04-29-2014, 09:05 AM   #6
Michael Beard
Michael Beard's Avatar
Liked 13 Times in 9 Posts
Posting for Phil:
Old 04-29-2014, 09:08 AM   #7
philbilly
philbilly's Avatar
Thanks Michael. That is 1 and 7 plug I changed number 7 that is one run on that plug.
Old 04-29-2014, 09:09 AM   #8
M Brand 505B
Liked 31 Times in 10 Posts
Does your cam have any of the cylinders swapped? I had two plug wires swapped on the dyno and the engine sounded decent but kept fouling out a plug. Also, what kind of top piston ring are you running? My plugs looked like that all the time when I ran a gapless top.
Michael Brand II
505B - F/SA
M Brand 505B is offline   Reply With Quote
Old 04-29-2014, 09:13 AM   #9
philbilly
philbilly's Avatar
Cam is norm firing order. All plugs look like 1 except 7. 7 doesn't never get hot like the rest. Head scratcher I have wore bald spots in my head since Friday.
Old 04-29-2014, 09:21 AM   #10
Rick Brown
Liked 45 Times in 8 Posts
Give me your phone number so we can talk about it, PM or otherwise! Rick Brown
Rick Brown is offline   Reply With Quote
