Old 04-28-2014, 12:26 PM   #1
joespanova
Liked 13 Times in 11 Posts
Default Locked timing , yes or no
In a drag race application , big block , automatic ..........any point in a vac advance...............I would prefer it just locked out .
This post is to advise someone else..............I want a concensus so he can decide.
Old 04-28-2014, 06:21 PM   #2
Ed Wright
Ed Wright's Avatar
Default Re: Locked timing , yes or no
Vacuum advance on a race car? Absolutely not.
Ed Wright 4156 SS/JA
Old 04-29-2014, 08:19 AM   #3
Chad Rhodes
The distributor should be completely locked out, and timing adjustment should be done by the ignition box
Chad Rhodes 2113 I/SA
Old 05-01-2014, 03:26 PM   #4
Jim Kaekel
Liked 535 Times in 110 Posts
Be sure that you have a start retard or you're bound to have serious kick-back issues during starting. Some start retards are built right into the ignition box and it may be just a matter of hooking it up and setting it.
Jim Kaekel 3836 STK
Old 05-01-2014, 06:31 PM   #5
1320racer
1320racer's Avatar
Liked 759 Times in 379 Posts
Drag race application...check
Big block...check
automatic...check
and the timing on my 950HP 522 is NOT locked out!
Easier starting, no kickbacks, no chipped flex plates, no busted starter drives.
MSD billet distributor, with largest bushing installed. Full advance is all in at 2200 IIRC.
Old 05-02-2014, 06:01 AM   #6
joespanova
Big block...check
automatic...check
I can see that........I think he ( the guy this is about ) just needs to spend more time with the distributor.
Old 05-02-2014, 06:21 AM   #7
Todd Hoven
Guest
Posts: n/a
I had the timing locked in my car, with not so good results. Tore teeth off of the flywheel once. Started when it was cold and cool. south of 130* water temp. As soon as it got warm, the engine would struggle to start. Rewired the car with new battery cables, better batteries, and it didn't get better. Soon as I installed the weight kit in the dist, my problems were solved. It started everywhere anytime.
If you run a 16volt battery, it may not be an issue
Old 05-02-2014, 07:39 AM   #8
Ed Wright
Ed Wright's Avatar
I have never locked my timing. I don't see the point. Only thing I ever locked was the mag in my sprint car, but that was a push start deal.
Old 05-02-2014, 08:25 AM   #9
Lew Silverman
Lew Silverman's Avatar
Liked 129 Times in 59 Posts
The timing of this post (no pun intended!) was perfect. I was just getting ready to lock the distributor on the 'wagon, but I think I'll keep the advance weights in it!
Lew Silverman #2070
"The Wagon Master" N/SA
Old 05-02-2014, 08:36 AM   #10
joespanova
I have it locked in my car.......and it works just fine that way.
