Old 04-23-2014, 02:51 PM   #1
Nick Heath
Liked 576 Times in 137 Posts
Default AHFS Changes (FWD/RWD GT Combinations)
http://nhraracer.com/content/general...810&zoneid=132
After reviewing SRAC member input regarding possible changes to the Automatic Horsepower Factoring System (AHFS), NHRA’s Technical Department released the following changes for the 2014 season.
Beginning January 1st 2014 the AHFS will review Super Stock GT front and rear wheel drive combinations separately. This is not an immediate across the board change, changes will be made only during the mid-year or end of year adjustments, or when a -1.20 under run occurs. At which point the review process will look to see whether a FWD or RWD combination caused the adjustment; only that combination will receive an adjustment.
Old 04-23-2014, 05:18 PM   #2
Bill Marshall
Liked 53 Times in 24 Posts
Default Re: AHFS Changes (FWD/RWD GT Combinations)
Does this mean we can get horse power taken off because a combo got killed by a front wheel drive car a few years ago ???
Bill Marshall is offline   Reply With Quote
Old 04-23-2014, 06:53 PM   #3
Tony Janes
Probably not.
Tony Janes 7941 STK, SS
Old 04-24-2014, 08:30 AM   #4
R GARY
Thumbs up Re: AHFS Changes (FWD/RWD GT Combinations)
should have different indexes also
R GARY is offline   Reply With Quote
Old 04-24-2014, 10:08 AM   #5
Bill Harris
Liked 26 Times in 13 Posts
If they are that different then they should not be in the same class. What's next, factoring based on the car's color... black cars absorb more heat than white cars so they have to be factored separately?
Bill Harris
ex 2172 STK
ex 2272 S/S
Bill Harris is offline   Reply With Quote
Old 04-24-2014, 12:30 PM   #6
Jeff Niceswanger
Liked 1,034 Times in 368 Posts
This is the AHFS policy wording...
•Body style and transmission type: Also considered in the above two screening processes are body style of the engine combination being reviewed and transmission type. Adjustments are only in effect for the specific car model being evaluated. The body style are generally classified by the OEM auto manufacturers' definition of "platform", i.e., the Camaro and Firebird body are both based on the same platform and therefore considered the same with regard to body-style classification. In some instances, however, more than one body style will trigger a review. With regards to transmission type, if the class average triggers the review, the adjustment would be for classes with the type of transmission triggering the change. However, if an engine family average triggers the review, the adjustment would be for all transmission types.
For what ever reason, for years this policy has been implemented on Stock, and Superstock, (ie 5 HP hit to "Corvette Only").... but Not on GT. They are now going to apply GT guidelines as the policy reads.
Jeff Niceswanger 3740 SS
Old 04-24-2014, 01:56 PM   #7
Bryan Worner
Liked 535 Times in 86 Posts
Exactly Jeff! Obviously Bill doesn't have a "combo" that has been effected by a FWD car hammering it with HP!
To help him, and any other Super Stock racers that don't understand why this change is necessary, here we go:
If said FWD conversion car is running GT/CA with combo A, and goes 1 second under time and time again, triggering a review in GT/CA, a RWD car running combo A CANNOT run GT/CA, to lower that average. It only fits into lower classes, therefore, even though the engine family average may be well under the .85 under mark, the combo still gets HP based on the GT/CA class average!
Bryan Worner is offline   Reply With Quote
Old 04-24-2014, 04:04 PM   #8
Patric Fox
Patric Fox's Avatar
Liked 11 Times in 8 Posts
I always thought the FWD conversions have a advantage with the engine placement , aftermarket front suspension components , and modifications allowed.
Patric Fox is offline   Reply With Quote
Old 04-24-2014, 05:50 PM   #9
R GARY
amen
