Liked 14 Times in 8 Posts
Hi
Im putting new control arm bushing and send it to alignment after what do you guys put caster camber ?? car is a 1969 nova G/SA thanks |
Liked 2 Times in 1 Post
This is what was suggested to us, for our Bracket cars:
Drag Racing Chassis Setup (For stock type chassis) Here is the alignment info. Toe-in = 1/16" Caster – 3 - 4 deg. Camber = 0 (at ride height raised up 3”) Driver’s weight must be in left seat. Re: drag race alignment specs Camber is zero but as the front end rises on launch, the camber goes out the window. Caster - as much as you can get. About 5 degrees on both sides. Toe would be good at zero but around 1/16" toe in is preferred.
RT - SS/X circa 1972. ![]() Talbot Racing Family |
Liked 166 Times in 46 Posts
I don't think you can get that much caster, if you could the front tires would be rubbing the back of the inner fender.
Liked 169 Times in 53 Posts
On my 69 Nova the most caster I can get is 3 degree's before it starts pulling the camber off of zero. This is with driver in car and front end raised up 1 1/2 inches . I agree with Jim that if I could get 5degree's caster that my front tire would probably be rubbing the back of the wheel well's.
Bill Bogues 4696 STK |
