Old 04-15-2014, 11:38 AM   #1
Jim Wahl
Jim Wahl's Avatar
Liked 683 Times in 129 Posts
Red face Onan Q4000 genset problem
OK so it was humming away with no problems on Friday at the race when it just shut off. Wouldn't restart. Let it cool off. Nothing. It will turn over and start and run until you take your finger off of the outside manual start button. Anybody got any ideas?
It is a 2011 Onan Q4000 with the flashing light trouble signal on the outside start button but the only code that gives is the "service" three blink code. ??? Jim
Old 04-15-2014, 12:15 PM   #2
Rich Biebel
Rich Biebel's Avatar
Liked 544 Times in 213 Posts
Default Re: Onan Q4000 genset problem
Jim if you push the button to stop once when it is still flashing 3 times, you should see a second fault code. Probably a series of two seperate blinks. If you can tell me what that is, I can give you more info. How many hours are on the machine?
Rich Biebel
S/C 1479
Stock 147R
Old 04-15-2014, 06:35 PM   #3
Jim Wahl
Jim Wahl's Avatar
Unhappy Re: Onan Q4000 genset problem
Rich, the code it gives me is 32. that doesn't make sense according to my manual. That code is shown as a "low cranking speed fault", but it's not cranking slowly.
My unit has 839 hours on it. Jim
Old 04-15-2014, 07:19 PM   #4
Rich Biebel
Jim check your message inbox....
Rich Biebel
S/C 1479
Stock 147R
Old 04-16-2014, 11:59 AM   #5
MacNicol Racing
MacNicol Racing's Avatar
Liked 11 Times in 6 Posts
Jim, I had a similar problem with mine years ago. I don't recall if it was the same code as you are getting though. Mine ended up being the circuit board. Replaced it and it started right up.
Kevin MacNicol 2120 STK & S/ST
MacNicol Racing is offline   Reply With Quote
Old 04-17-2014, 09:26 PM   #6
Jim Wahl
Jim Wahl's Avatar
Question Re: Onan Q4000 genset problem
Thanks Mac. Rich, I answered you, did you get it? Jim
