Go Back   CLASS RACER FORUM > Class Racer Forums > Factory Stock and Super Stock
Old 04-10-2014, 12:07 PM   #1
Nick Heath
Liked 576 Times in 137 Posts
Default Factory Stock Showdown Rule Revisions
http://www.dragracecentral.com/DRCSt...UMMIT#indextop (also on NHRAracer.com)
All supercharged vehicles will compete within the FS/A class.
All naturally aspirated vehicles will compete within the FS/B class.
Index for the FS/B will be lowered from 10.40 to 10.35
FS/A minimum weight will be adjusted from 3500LBs to 3550LBs
300LBs will be added to the V-10 Dodge Challenger
FS/B: Minimum weight up to 400 CID 3250 LBs, 401 to 430 CID 3350 LBs
Old 04-10-2014, 01:30 PM   #2
rickseeman
rickseeman's Avatar
Liked 2 Times in 2 Posts
Default Re: Factory Stock Showdown Rule Revisions
Wow, I don't know much about that kind of stuff but isn't adding 300 lbs to combo pretty aggressive? I mean were they running off and leaving everybody? 300 lbs?
rickseeman is offline   Reply With Quote
Old 04-10-2014, 02:10 PM   #3
Nick Heath
They were running in FS/A with the blower cars at 3200 lbs.
Now, they're running in FS/B with the other NA cars at 3500 lbs and the index is 0.25 slower.
So, without going back and looking at the data and/or consulting with V-10 owners, I'd say a +300 lb. change is a bit excessive, but it could give them a better chance to be competitive since they don't have to run with the supercharger combinations...
Old 04-11-2014, 12:24 AM   #4
David Barton
Sponsor
Actually, we requested this change because even a light V10 car is 3200 lbs without a driver. So even a light driver was 150 lbs heavier than the minimum weight. It makes much more sense now, they can run with the rest of the NA cars and meet the minimum weight. It also helps the car count in FS/B since most decide not to show.
David Barton is offline   Reply With Quote
Old 04-11-2014, 02:44 PM   #5
Tom P
Liked 239 Times in 94 Posts
I thought a street V8 Challenger was around 4200 lbs, how were they able to add a heavier V10 engine and drop 1000 lbs? Is there really that much electronic stuff and sound deadener in new cars?
Old 04-11-2014, 04:01 PM   #6
Michael Beard
Michael Beard's Avatar
Liked 13 Times in 9 Posts
I've been keeping an eye on this. I didn't utilize the Factory Stock program for this year's Auto Meter Northern Class Nationals because it seemed like there was a lot of sorting out to do. I would be interested in sitting down with all the drivers at our event to discuss 2015.
Old 04-11-2014, 08:10 PM   #7
Dan Wilson
Yes
Dan Wilson, STK3171, K/SA
Dan Wilson is offline   Reply With Quote
Old 04-13-2014, 10:24 AM   #8
Dan Wilson
should the 430 be 450ci?
Dan
Old 04-13-2014, 11:02 AM   #9
RJ Sledge
Liked 294 Times in 93 Posts
I understand that this deal is a "Work in Progress", but why are they excluding, by the weight breaks mentioned, the smaller cubic inch versions from the Manufactures. For example the CJ 352 and the Mopar 360, not sure of the Copo situation.
If you had the minimum weight at 3050 lbs in FS/B for smaller cubic inch combo's, it would allow the smaller cubic inch motor to be able to run FS.
Why eliminate them by putting the mimimum at 3250 up to 400 cubic inch???
RJ
RJ Sledge is offline   Reply With Quote
Old 04-13-2014, 11:27 AM   #10
Dan Wilson
I agree. Min weight starting with the smallest ci and adjust weight with ci sizes. Weight per ci.
Dan
