Old 03-29-2014, 11:34 AM   #1
Mark Ruset
Mark Ruset's Avatar
Liked 43 Times in 29 Posts
Default BG 20-50 Racing Oil
Just came across a case of this BG 20-50 racing oil and was wondering if anyone has any recommendations for it. Either it's ok to use or stay far away from it. The application for use would be a 275/327.
Mark Ruset 2048 STK
Mark Ruset is offline   Reply With Quote
Old 03-29-2014, 12:39 PM   #2
Liked 1,789 Times in 408 Posts
Default Re: BG 20-50 Racing Oil
Mark,
I'd be just about stunned if your little 327 needed or wanted anything close to 20W50, I don't even run that stuff in the 750HP 396 Super Stock engine. The thickest oil you should ever need or want is probably 10W30. That thing would probably be real happy with 0W20, or 5W30, unless it is a lot looser than I think it is. Thick oil just slows you down, and wears the distributor gear (on the distributor and the cam) among other things. If it makes you feel better, I'd say 10W40 in the summer down there in the heat, in bracket mode would be okay. If you're running 20W50 now, you'll probably find a fair amount of ET in 0W20 or 5W30.
Old 03-29-2014, 03:23 PM   #3
Lee Valentine
Liked 319 Times in 68 Posts
Just run glue, it's cheaper and probably faster.
Lee Valentine 1661 STK
Old 03-29-2014, 03:54 PM   #4
Dave Noll
Dave Noll's Avatar
Liked 238 Times in 111 Posts
If you use that oil, use a heater with it as well. A 50 weight @ 212 degree's is thinner that a 0 weight @ 75 degree's.
Dave Noll, EF/S ,?/SA 6526
Old 03-29-2014, 04:04 PM   #5
james schaechter
Liked 1,428 Times in 296 Posts
Originally Posted by Alan Roehrich View Post
Mark,
Find someone that loves it and trade for a more appropriate viscosity for your engine. There has to be a copo, dragpak or cj dying to scrub off some more HP! :-)
James Schaechter 3163 STK
Old 03-29-2014, 04:19 PM   #6
SBDART
SBDART's Avatar
I used to run 50 w in my 340 dart some years ago . now that I have a new motor 416 storker to go down in it before I start it up what would be a good lifeable oil to run in it. just asking???
Larry Anderson
71 Dart Swinger 416 Storker (Augie).
http://i58.photobucket.com/albums/g2...11/Dart416.jpg
SBDART is offline   Reply With Quote
Old 03-29-2014, 05:55 PM   #7
Dave Noll
Dave Noll's Avatar
Larry, I'm not a Mopar guy but they are all engine's. Alan's advice is sound. I said what I did because a 20-50 was a popular oil for the roundy guy's but those motor's spend some time getting warm & buy the time the race is hot & heavy, the oil is @ 20 centistokes. Not so much in our drag racing. (unless it's a street/strip car driven to the track) I spent some time reading here:
www.bobistheoilguy.com
Then I put a wide sweep oil pressure gage in my daily driver (95 escort w/195,000 miles) & started playing with grade's. I know my racecar has different needs, but it's interesting.
Old 03-29-2014, 05:56 PM   #8
Mark Ruset
Mark Ruset's Avatar
Thanks Alan and to all that replied, I've never used anything else but Valvoline 10/30. I'll keep the BG far away from the Camaro.
Mark Ruset 2048 STK
Old 03-30-2014, 06:44 AM   #9
SBDART
SBDART's Avatar
thanks... I like lucas oil that's what I run in my old dart and what I was going to run in the new car and engine...the reason I use lucas is because I had some work done on the last motor an when the guy I had doing the work ask what kind of oil I was using I said lucas he said that the bearing had little or no wear in them . but I do use Valvoline in my truck and my wife car big fan of it. what about the VR1 from Valvoline??? I have heard that some like it for a race oil and a good break in oil. I don't know how true that is.
Larry Anderson
Old 03-30-2014, 08:33 AM   #10
Myron Piatek
Liked 138 Times in 51 Posts
Post Re: BG 20-50 Racing Oil
As outlined, while the BG 20w-50 is a higher viscosity than needed for drag racing, especially for Stock, it may at least have higher levels of zinc & phosphorous most people recommend for older performance & race applications, as well as break-in. But you have to do some research to know which oils still have higher levels. "Shelf" oils for newer cars and diesels have had a lot removed and even some racing oils don't emphasize the ppm content.
It's explained a bit more in this Amsoil bulletin:
http://www.amsoil.com/techservicesbu...t%20Tappet.pdf
Of course, if you have Schubeck/Smith lifters, it isn't as critical.
LOCOMOTION Racing
