Old 03-28-2014, 07:16 PM   #1
Rob Petrie E395
Liked 216 Times in 77 Posts
Default TH350 Question
On a TH350. If you were to kill the engine after the finish line and then put it in neutral would it hurt the transmission? I know unless you have clean neutral you cannot just shift it to neutral or it will do damage. What I am wondering is since the output shaft is still turning but the pump would not be would damage it.
Thanks
Rob
Old 03-28-2014, 07:25 PM   #2
Ed Wright
Ed Wright's Avatar
Talking Re: TH350 Question
Thanks
Rob
Rob, you need Rossler's (or somebodies) Clean Neutral feature. Takes a different shifter also. I learned this the hard way. Never put it in neutral in shut-down without it. Got away with it a couple of times, then it bit me.
Ed Wright 4156 SS/JA
Old 03-29-2014, 10:36 AM   #3
Rob Petrie E395
Default Re: TH350 Question
What about Killing the engine but leaving it in gear? Or would that do the same thing as going to neutral with engine running?
Old 03-29-2014, 10:42 AM   #4
Ed Wright
Ed Wright's Avatar
Don't know about that one. I wouldn't do that myself. What Carl Rossler told me when I messed mine up was "Multiply your engine RPM by your first gear ratio, that is how fast that drum spins up to when you put in neutral in the lights."
Old 03-30-2014, 08:56 PM   #5
jmantle
Liked 172 Times in 81 Posts
As soon as you shut off the engine, the pump stops turning and all the clutches disengage. The safe neutral valve bodies keep the high gear clutches applied so everything in the gear train is turning the same speed as long as you don't shut off the engine.
Jim Mantle V/SA 6632
jmantle is offline   Reply With Quote
Old 04-06-2014, 04:02 PM   #6
CrateCamaro
CrateCamaro's Avatar
Liked 19 Times in 7 Posts
TCI and Turbo Action forward pattern valve bodys can be nutraled and does not hold the clutches on. I just changed over from TCI to TA and called and asked if i could nutral it and the answer was absoutely yes.
Tony Valerio 1968 Camaro
1700 IHRA H/CM
1701 NHRA SS/?A
Old 04-06-2014, 05:07 PM   #7
Ed Wright
Ed Wright's Avatar
Rossler has that as well as ProTrans. My Rossler was bought used, and did not have "clean neutral".
