Old 03-27-2014, 04:26 PM   #1
Jody Lang
Liked 89 Times in 28 Posts
Default Wet plugs on one side....
Wet with fuel, dry on the other bank. Idles fine just making no heat on the one side.
Stocker with dual plane manifold.
Any ideas?
Jody Lang is offline   Reply With Quote
Old 03-27-2014, 04:31 PM   #2
Jody Lang
Default Re: Wet plugs on one side....
This is just being ran in the shop, not after making a pass.
Chev 305 Q Jet
Old 03-27-2014, 04:39 PM   #3
ss3011
ss3011's Avatar
Liked 239 Times in 114 Posts
Wet from oil or gas ?
Old 03-27-2014, 04:44 PM   #4
rod butcher
Liked 132 Times in 27 Posts
I had a bad MSD 7AL2 that caused something similar. I tried 2 carbs, plugs, a set of wires before I stumbled on to it.
rod butcher is offline   Reply With Quote
Old 03-27-2014, 05:02 PM   #5
Jody Lang
Fuel.
This is a buddies car so I might not have all the correct answers.
Thanks
Old 03-28-2014, 01:47 AM   #6
Phillip marvetz
Phillip marvetz's Avatar
I've had something plug up the idle circuit and do something like that on a small block ford.
2009 V/SA Record Holder
Old 03-30-2014, 01:55 AM   #7
Liked 5,121 Times in 1,952 Posts
Shouldn't affect just one head with a dual plane intake.
Old 03-30-2014, 07:33 AM   #8
JimL
What kind of distributor does it have in it?
JimL is offline   Reply With Quote
Old 03-30-2014, 10:15 AM   #9
Tom keedle
Tom keedle's Avatar
Liked 8 Times in 7 Posts
sounds like the intake gasket is leaking to me...
Old 03-30-2014, 02:17 PM   #10
Not too much else that could cause this.
Ignition would have to drop every third, then every second cylinder, etc, consistently.
