Old 03-25-2014, 08:11 PM   #1
Bill Belden
Bill Belden's Avatar
Default Light Weight Batteries
Any recommendations?
Bill Belden
Retired Stock Eliminator
[emailSTK1100@comcast.net[/email]
Bill Belden is offline   Reply With Quote
Old 03-25-2014, 08:38 PM   #2
FED 387
Liked 335 Times in 182 Posts
Default Re: Light Weight Batteries
what are you trying to accomplish and is cost a consideration----FED387
Old 03-25-2014, 08:53 PM   #3
Bill Belden
Looking to replace battery in stocker, cost is a consideration, however we all know that cheaper can cost more in the long run
Bill Belden
Old 03-25-2014, 08:58 PM   #4
FED 387
next ? how light is light?? personally I would look at a Braille or ,Deka (you can get DEKA at NAPA) or a Shorai which is a carbon fiber lithium ion battery both of these are 12 volt but you can get 16 volt too ---better get your wallet out if you go with carbon fiber or 16 volt they get pricey real quick
Old 03-26-2014, 02:06 AM   #5
HandOverFist
HandOverFist's Avatar
Liked 33 Times in 16 Posts
Just updated our Stocker with a Braille B3121 - 755 cranking amps and 21 lbs. We probably could have gone with the 18lb battery, but I'm a worry wart.
Rich Taylor
I/SA - 321
Old 03-26-2014, 03:44 AM   #6
cad
cad's Avatar
Liked 93 Times in 52 Posts
This Odyssey battery turns my 13:1 383 with solid roller valve springs.
It has 900 amps for 5 seconds.
http://shop.odysseybattery.com/p/pc925-a
http://www.jegs.com/i/Odyssey-Batter...PC925/10002/-1
Not sure why Jegs is so expensive. It is available at several places.
$147 -- http://www.amazon.com/Odyssey-PC925-.../dp/B0002ILK72
You will need to use metric bolts for the lugs or purchase the additional posts for post style.
Old 03-26-2014, 08:35 AM   #7
Sean Marconette
Sean Marconette's Avatar
Liked 275 Times in 76 Posts
Odyssey here as well. Pay attention to the part numbers if you are looking at Jegs or Summit. You do not want the battery with the MJ, it is a metal jacket, and adds weight. As Cad pointed out get the lugs, and the specific charger is a good investment. My first Odyssey lasted 5 years and failed during the off season. Battermart.com is where I have bought mine as they have free shipping and the battery has a 2 year warranty.
Sean
Sean Marconette
84 Mustang
5060 SS/N
Old 03-26-2014, 08:35 AM   #8
Rsmith38
Liked 28 Times in 15 Posts
Deka powersports batteries are AGM and half the cost of the Brand Names (Braile, etc) I have used the 18 lb and will replace it with the 21 lb this year. With FI and FI fuel pump, elect fan and WP, FI computer, etc the 18 lb is marginal if going rounds without time for charging. You can search Google or Amazon for the Deka batterys. (They may be the maker of the NAME batterys specs and weights seem the same))
Rsmith38 is offline   Reply With Quote
Old 03-26-2014, 03:48 PM   #9
Bill Belden
Thanks all, I'll look into the Braille and Deka batteries
Bill Belden
Old 03-26-2014, 04:21 PM   #10
Don Fardie
Don Fardie's Avatar
Hey Bill I've been running the PC925MJT - Odyssey*battery for 6 years and no problems but thinking of switching to the Braille B14115C. It's pretty much the same cranking stats but half the weight. Only 11.5lbs compared to Odyssey 26lbs. Of course it's 100 bucks more
Don Fardie 1582 F/S B/G
Don Fardie is offline   Reply With Quote
