Old 03-10-2014, 04:50 PM   #1
Squirrell
Default Dedenbear Case
Hi Guys, can anyone tell me if you need to make the holes any larger in a Dedenbear case for the transbrake to dump the fluid ?. Box is fitted with a TCI Probrake. The guy I bought the car from has drilled a hole near the standard 3/8" hole and modified the valve body to allow fluid to come out the new hole as well. I forgot to take photos when I had it apart. he then had a problem with the car creeping so he plugged the hole. My question is do you need to put any extra holes in to make the transmission dump faster ?. Has anyone had any problems with a TCI Probrake ?. Car is still a little slow leaving on a .400 Pro tree.
Thanks for your help, Patrick.
Squirrell is offline   Reply With Quote
