Old 02-26-2014, 01:44 PM   #1
Sean Marconette
Sean Marconette's Avatar
Liked 275 Times in 76 Posts
Default Foxbody headers
Just curious what others are using. My hedmans that were the trick header when Evan Smith built the MMFF project stocker, have developed several cracks. I am looking at headman # 85617 that are a stepped header. The Kooks headers just seem to have too big of a primary tube from what I am seeing.
Thanks
Sean
Sean Marconette
84 Mustang
5060 SS/N
Old 02-26-2014, 04:13 PM   #2
west coast
Liked 223 Times in 73 Posts
Default Re: Foxbody headers
I have been using the Pacesetters they fit well in the chassis. I cut the collector off and used merge collector from performance welding.
James Boyce 6052 K/SA Stock
National record holder 2015,2018,2 times in 2022,2023
west coast is offline   Reply With Quote
Old 02-26-2014, 10:25 PM   #3
partsbob67
Liked 79 Times in 11 Posts
I use hedman also. love the fit and overall quality.
bob beals 7244
partsbob67 is offline   Reply With Quote
Old 02-27-2014, 02:04 AM   #4
Rory McNeil
Liked 1,104 Times in 302 Posts
I have 1 5/8" FlowTech long tubes on my Mustang. I can`t say how they compare to anything else, since they are the only set I`ve tried to date. They are reasonably priced, clear the scattershield fine, and they won`t need collector tethers!
NHRA 6390 STK
M/S 85 Mustang
Old 02-27-2014, 09:43 PM   #5
Don Anderson
Liked 24 Times in 8 Posts
Sean,
1 1/2" Hooker Header with Ed`s collectors work on my Stocker.
Don Anderson
M/S #5342
Don Anderson is offline   Reply With Quote
Old 02-28-2014, 06:21 PM   #6
Alex Denysenko
Alex Denysenko's Avatar
Liked 4 Times in 3 Posts
out of the box you can't beat the flowtechs for fit and performance we stock and sell a lot of them
we replaced them on Beth's car with a set of the headman step headers and saw virtually no improvement untill we installed mark' lelchock's collectors on them so ANY 5.0 stocker we build from scratch gets them and i would build another one if IHRA would ever get there act together and straighten out how about a minus 2.00 second under pure stocker? Fast and consistent so even a cripple like me could drive it and go rounds after qualifying #1
Alex Denysenko NHRA 3038 SS, 3305 STK - IHRA 6 SS, 330A STK
Moneymaker Racing LaPorte Indiana 219-861-1214
www.moneymakerracing.net
Alex Denysenko is offline   Reply With Quote
Old 03-02-2014, 12:47 PM   #7
Sean Marconette
Thanks for all the responses. As others have found the results seem to be in the collectors. I have tried the original slip on collectors, the flowmaster scavenger merge collectors. All of these with and without an X-pipe. The flowmaster by far had the best results. I will be looking into the collectors that have been listed.
Thanks
Sean
Sean Marconette
84 Mustang
5060 SS/N
Old 03-09-2014, 02:30 AM   #8
D Styron
As far as the flow techs go is it worth the extra $100 or so to buy the ceramic coated version or is their coating not any good? No doubt Jet Hot would be better, but is it worth the extra $?
D Styron is offline   Reply With Quote
Old 03-09-2014, 10:29 AM   #9
fordteacherguy
Liked 160 Times in 51 Posts
The ceramic coat on Flowtechs is only on the outside, not on the inside of the tubes. less expensive and pretty under the hood, but the inside tubes do deteriorate. I like to buy the plain sets and have the headers coated inside and out and just do it once. They last much much longer and keep your engine from inhaling rust after it sits!
FYI, I also build my own merge collectors with the diy kits from Cone Engineering.
fordteacherguy is offline   Reply With Quote
Old 03-09-2014, 10:46 AM   #10
Tand E racing
Ditto on the cone engineering collectors worth the money. hedman #88390
Tand E racing is offline   Reply With Quote
