Liked 1,660 Times in 509 Posts
I need to replace my fuel pressure gauges. I have one mounted on the regulator and one on the cowl. The one on the cowl is not reading correctly and the one on the regulator is a cheapo one and the needle bounces around so much you cant get a good read on it. Any one have a good recommendation? what about the ones with an isolator? I still want one on the cowl and one on the reg under the hood.
Thanks,
Mike Pearson 2485 SS |
Liked 2 Times in 1 Post
If the gauge on the cowl is liquid filled, there should be a screw somewhere around the top of the gauge. Loosen that screw and let it sit for a few minutes and that should equalize the pressure from the inside of the gauge to the outside. It has to do with temperature and barometric pressure. Derek
Derek Hake 4459 H/SA 69' Roadrunner |
#3 | |
Liked 4 Times in 3 Posts
we have old Autometer probably even older on my Mustang AND OLD OIL FILLED LITTLE HOLLEY ON THE REGULATOR, BOTH WORK AS GOOD AS NEW I should have some of each in stock I replaced a even older chrome Sun that failed with the AUTOMETER, a eon ago and Tom Jenkins gave us the little Holley ones for all 3 cars when he was with Holley they were so failproof we started to sell them
Alex Denysenko NHRA 3038 SS, 3305 STK - IHRA 6 SS, 330A STK Moneymaker Racing LaPorte Indiana 219-861-1214 www.moneymakerracing.net |
Liked 6 Times in 4 Posts
Why do you want one on the reg. and the cowl? They never match and only confuse you. I say put one on the cowl (if it's a race car) and use it....
PS: and forget about a liquid filled, in the under hood heat. I could never get one to read right in that environment... |
