Old 01-22-2014, 04:33 PM   #1
njk53
Default Lower Octane Fuel
I was wondering why the NHRA doesn't allow/approve VP, Sunoco, etc to manufacture a leaded race fuel that is in the 95 to 98 octane range. I know in our situation with a 9:25:1 compression ratio motor, our car would run much more efficient on a lower octane fuel. There has got to be a lot of stockers out there that have lower than 10:0:1 CR and would also benefit from a lower octane fuel. I don't think it would be that difficult to check or am I wrong?
Nelson Kowal
Stock 345
Old 01-22-2014, 04:55 PM   #2
Pistol Pete
Pistol Pete's Avatar
Liked 795 Times in 210 Posts
Default Re: Lower Octane Fuel
I am thinking the same.
VP C9 might be that fuel You & i need.
"Pistol" Pete Dutko
Old 01-22-2014, 05:47 PM   #3
Bob Bender
Bob Bender's Avatar
Liked 460 Times in 91 Posts
We use vp-C 9 in 4 cycl stocker. Works great.
Bob Bender 144 O/SA
Old 01-22-2014, 08:16 PM   #4
7423
What is the octane of the C9 and what does a 5 gal pail cost??
I just priced C10 in SoCal at $72-$82 a pail. Totally obscene!!
Two years ago it was $50 a pail out here.
7423 is offline   Reply With Quote
Old 01-22-2014, 08:38 PM   #5
Bob Bender
Bob Bender's Avatar
I think it was like 53.00 a gal from VP last year, octane is 98.
Bob Bender 144 O/SA
Old 01-23-2014, 09:33 AM   #6
njk53
Is the C9 VP Leaded or Unleaded?
Nelson Kowal
Stock 345
Old 01-23-2014, 09:58 AM   #7
Greg Reimer 7376
Liked 705 Times in 219 Posts
Cool Re: Lower Octane Fuel
We have a couple of '68 Chevelles with the 327/250-245 horse engine. that engine,even after decking the block and the heads and arriving at a comfortable chamber size, is an actual 8.5 c/r. It runs fine on 91 octane 76 union right from the pump. No real difference in Et or MPH is obvious from C-12. It probably shouldn't do this according to conventional wisdom, but Tony Janes did this when bracket racing the car. I always hunted down C-12 when I went out, but there's apparantly no need for 108 octane fuel in an 8:1 engine. Problem is, the 76 wouldn't pass fuel check, so when Pomona comes, out it goes and the good stuff has to go in. I don't think we would try this with the 275 horse engine.
Old 01-23-2014, 10:42 AM   #8
7423
My car @ 9.1 CR is .05 faster on Arco 91 pump gas then on the legal fuels VP C10 or Rockett 111. I believe that well over half of the stockers would run just fine on pump gas at $4.00 a gallon instead of the rip off prices we are forced to swallow for the $13.00 and up per gallon fuel on the "accepted" list. But I guess thats politics...............
Old 01-23-2014, 11:18 AM   #9
Signman
Liked 269 Times in 99 Posts
VP C-9 is 97 octane Unleaded with NO Oxygenates.
As close as you can get to pump gas with NHRA approved fuel from VP.
It is cheaper (around $65 with the can) is all gasoline not as caustic as other VP Fuels.
Keep in mind it is unleaded, if using older heads without hardened valve seats you will have issues.
Old 01-23-2014, 12:39 PM   #10
B Parker
Liked 2,336 Times in 464 Posts
I use C-9 all the time. My car likes it better than the rest of VP's fuel. I have had my fastest pass with it. Just have to tune it a little. BP
