Old 01-12-2014, 07:13 PM   #1
Ross Family Racing
Liked 51 Times in 14 Posts
Default Are synthetic oils and lubricants any quicker
Just got done installing a new braced up rear end housing in my Cuda and now I,m wondering if synthetic gear lube is worth the money and is there any Et in it. If so what brand , weight ect did you use??
Jeff Ross
Ross Family Racing is offline   Reply With Quote
Old 01-12-2014, 07:16 PM   #2
1320racer
1320racer's Avatar
Liked 759 Times in 379 Posts
Default Re: Are synthetic oils and lubricants any quicker
more ET to be had in running less lube/oil than there is in type.
Old 01-12-2014, 07:36 PM   #3
340Cuda
Liked 805 Times in 341 Posts
My experience with synthetic oil in the rear end is that the first run of the day will not be slower than the second run all other things equal.
Bill
Old 01-12-2014, 09:24 PM   #4
Ed Wright
Ed Wright's Avatar
Bill, that is about all I noticed.
As far as running less lube, I would not recommend that. I use Royal Purple 80wt in mine.
It holds almost two bottles. I was running one thinking about drag, or "windage". At Indy in 2011 James Lee rode up there with me. We were parked across from long time hero of mine Jimmy Bridges. He told James about testing he did on the bench with a rear end he rigged up with a clear back cover so he could watch the line at speed. I don't remember the speed he told James, but most of the lube goes out into the axle tubes. Low lube levels cause the gear set to run out of lube sooner, or at a lower speed.
After hearing that I dumped the other bottle of lube in my rear end. Ran my first MPH over 132. Wasn't sure if I could believe it until my MPH stayed about half a MPH for the rest of the year. My gear life is better to boot. With the lube going to the axle tubes, drag on the gears running in the lube becomes moot. If that info came from somebody other than Jimmy, I might have not been so quick to believe it. Jimmy tests about everything.
Hope this helps somebody else.
Ed Wright 4156 SS/JA
Old 01-12-2014, 09:32 PM   #5
1320racer
1320racer's Avatar
The fact is many class racers and some bracket racers run less than "2 bottles." I haven't run more than 1 quart of Mobil 1 Synthetic gear lube in over 2 decades and the R&P on my Firebird failed after 700+ runs 60 footing low 20's to high teens and my 3880 lb. chevelle typically got 200 passes on a R&P 60 footing 30s and a best of 1.28.
Old 01-12-2014, 09:55 PM   #6
Ed Wright
Ed Wright's Avatar
Many people doing something does not make it correct.
I don't break rear ends, they just stay quieter longer. Less wear.
When it comes to listening to you or Jimmy Bridges, well....
Old 01-12-2014, 09:59 PM   #7
HP HUNTER
Liked 373 Times in 129 Posts
Ed, thats a no brainer LOL
Old 01-12-2014, 10:06 PM   #8
1320racer
1320racer's Avatar
I typically make 250+ passes a season and you?
Old 01-12-2014, 10:13 PM   #9
Ed Wright
Ed Wright's Avatar
And I should care because?
Old 01-12-2014, 10:18 PM   #10
1320racer
1320racer's Avatar
the point is I as do most serious bracket racers, make far, far more passes in a season that you do who "don't break rear ends"
Nothing breaks when it's sitting in the trailer.
