Old 12-22-2013, 03:40 PM   #1
Steve Stickel
Steve Stickel's Avatar
Liked 50 Times in 23 Posts
Default Battery Placement IHRA Crate Motor ?
Question ,
Rule book says
" Trunk mounted battery legal " So, I'll assume that no other stock location mounted battery is required ? Just one in the trunk and that's it?
Also, I don't see any links to cylinder head runner volumes on the IHRA site.
Does a list exist? or use the NHRA information?
Thanks in advance for your advice
Steve Stickel
1161 Stk
1167 SS
Steve Stickel is offline   Reply With Quote
Old 12-22-2013, 05:13 PM   #2
Myron Piatek
Liked 138 Times in 51 Posts
Post Re: Battery Placement IHRA Crate Motor ?
Yes, trunk only is acceptable in a crate motor car. You just have to add a kill switch.
Runner and chamber specs are the same as NHRA based on the head casting numbers. Numbers for any superceeded/allowed heads that are IHRA only would need to be checked through one of the IHRA tech officials.
LOCOMOTION Racing
