Liked 2 Times in 2 Posts
Looking for the pro's and cons of whether to use a poly fuel cell or aluminum.Any thoughts? (drag race application)
Liked 695 Times in 206 Posts
I have seen racers have problems with the aluminum tanks cracking.
Aluminum tanks require care in mounting so as they do not crack
Liked 138 Times in 51 Posts
Cracks may result from being mounted by the 4 tabs onto an uneven or flexing surface. I believe it's suppose to be secured with straps. I think there was a discussion somewhere about that. I must admit that I use the tabs and haven't gotten around to adding straps. But my aluminum cell is mounted on boxed-in rails spanning the spare tire well. That creates a flat, stiffer foundation and helps isolate the cell.
LOCOMOTION Racing |
Liked 229 Times in 99 Posts
I've got a custom made one that fits under the bed of my pickup. It's mounted with tabs and straps with rubber insulators. Every seam on it has been rewelded over a few years.
Floyd Staggs 787 SST |
Liked 6 Times in 4 Posts
I have had an aluminum cell (16 gal) mounted in my trunk the same as Myron's for probably 10 years.... Never a leak... I hope I didn't just jinx myself ;-)
Liked 7 Times in 6 Posts
I mounted mine with firm rubber strips under the tabs. Hasn't leaked in 6 years, but I never knew of this problem. Now I'm worried. I just went through the stock Nova trunk floor with 3/8's bolts.
Liked 279 Times in 68 Posts
5gal. Aluminum since the first year they were legal in stock with no problems.
Greg Hill 4171 STK |
Liked 2,361 Times in 558 Posts
The first one I did was poly. It always seaped around the fittings. I switched to using aluminum on all my cars and have never had an issue since.
Liked 4 Times in 3 Posts
Stainless !
