Old 12-07-2013, 05:07 AM   #1
rodrocket
Default Mega 450 Wiring Help
Greetings all
I have a Mega 450 box & need to wire it into my car, the car was previously a manual with a Digital 7 & Koni Electronic shock control box
I don't want to tear any of the wiring out of the car as we will go back to a manual & will need the switch on the gas pedal & also the switch on the clutch pedal
I have drawn the complete wiring diagram that's in the car in Microsoft Publisher, if somebody has publisher & can help I am happy to email them the wiring diagram
regards
Rod
rodrocket is offline   Reply With Quote
Old 12-07-2013, 11:41 AM   #2
cad
cad's Avatar
Liked 91 Times in 51 Posts
Default Re: Mega 450 Wiring Help
Send me the file and I can convert it to a jpg or PDF.
cdoukas@gmail.com
Clark
Old 12-07-2013, 08:55 PM   #3
RacingRicki
Sponsor
RacingRicki's Avatar
Do you have the manual for the Mega 450. You can download it from Digital Delay (see link below). This should help.
http://www.racedigitaldelay.com/pdfs...mega350450.pdf
Also if you have specific questions, ask away. You are more likely to get help.
RacingRicki
RacingRicki is offline   Reply With Quote
Old 12-07-2013, 11:16 PM   #4
rodrocket
thanks Clark, email sent
Ricki, my concern is to were to wire the box into the car, I have Penski rear shocks with the Koni controller & want to make sure that they work in Burnout mode & also Race mode
I don't believe we will need the bump up & bump down buttons so I am notcncerned with them
we don't have a start line enhancer just a plate style under carb stop
the issue's that I am up against is this car was originally a manual with the switches on the Gas & Clutch pedals to trigger the shock controller & I don't want to remove any wiring as we will put the car back to manual eventually
regards
Rod
Old 12-08-2013, 09:33 PM   #5
GaryGoFast
Talking Re: Mega 450 Wiring Help
If I understand you correctly, car was a manual and now an automatic and you need to control your electric shocks. I have Koni electric shocks with an on/ off switch by shifter as well as a micro switch on tranny linkage. The micro switch starts the timer after the 1-2 shift and the on/off switch is too reset timer after burnout or leave them off til after burnout. Really don't need the Mega involved.
Gary Federico
S/St, S/G 1814
GaryGoFast is offline   Reply With Quote
Old 12-08-2013, 10:58 PM   #6
rodrocket
thanks for the reply Gary
yes I have the Koni controller in the car to control the shocks & a switch above me to switch from Burnout mode to Race mode
they will need to be controlled to trigger in conjunction with the Transbrake release
the Mega 450 will also control the throttle stop
regards
Rod
Old 12-09-2013, 11:48 AM   #7
RacingRicki
Sponsor
You won't be able to control the shocks with the transbrake button if you want to be within the rules. The rule is pretty clear in that there must be only one continuous wire from the transbrake output to the transbrake solenoid with no splices.
Does it have to be triggered on transbrake release or transbrake button release?
RacingRicki
Old 12-09-2013, 06:21 PM   #8
rodrocket
thanks Ricki
nothing in our regulations here in Australia about that so I am able to joint it in there somewere
Old 12-10-2013, 02:20 PM   #9
cad
cad's Avatar
Rod - here is the link to the PDF. This folder on Dropbox should be "shared" so everyone can see it.
https://www.dropbox.com/s/m6l1b6jh8r...ro%20Stock.pdf
Clark
Old 12-10-2013, 06:53 PM   #10
rodrocket
Clark
thanks for that Clark, much appreciated
regards
Rod
