Old 11-23-2013, 12:31 PM   #1
Speedy Peets #4103 I/SA
Liked 5 Times in 4 Posts
Default 75 nova door pins bushings
On my 75 Nova, My Left Door is sagging, I can see the pins on top and roller pin on bottom needs to be replaced, has anyone replaced them, and how much of a hassle is it? Or be better off replacing whole hinge? Seems to be welded in, Any idea`s?
Speedy Peets #4103 I/SA is offline   Reply With Quote
Old 11-23-2013, 10:31 PM   #2
Bob Emery
Default Re: 75 nova door pins bushings
I used a bushing kit from Classic Industries on my '72, didn't need to replace the hinges. Wasn't a big hassle at all, used a floor jack at the back of the door for support and was a one person job.
Bob Emery is offline   Reply With Quote
Old 11-24-2013, 11:27 AM   #3
Thanks for the info,,,
Old 11-25-2013, 09:49 AM   #4
njk53
I think you can get a door pin kit (bushing and pins) in the Dorman or Help line at any good auto part store.
Nelson Kowal
Stock 345
Old 11-25-2013, 11:15 AM   #5
HandOverFist
HandOverFist's Avatar
Liked 33 Times in 16 Posts
Lower hinges usually take most of the brunt of wear. A new lower hinge along with new pin/bushing for the upper will take care of the sag. http://www.classicindustries.com/197...q=door%20hinge
Rich Taylor
I/SA - 321
Old 11-25-2013, 12:56 PM   #6
Lyn Smith
Liked 1,007 Times in 204 Posts
Is your lower hinge welded in? Some of the x bodies had welded hinges.i know my 70 does.Not easy to replace.rebuilding it would be a better option.
Lyn Smith is online now   Reply With Quote
